Go Back   Home > Forums > General Interest > Car Audio
Old 15th February 2009, 02:43 AM   #1
Send a message via ICQ to Samuel Rock Send a message via MSN to Samuel Rock
Default Pic chip in orion 275R
i had some one bring me an ORION 275R today.. said it has engine noise.
so i hooked it up on the bench and it had poping noise comming from both channels.. after a bit of testing i started to think i was hearing the 1mhz from the crystal.. to make a long story shot i ended up pulling the pic chip from my working 275G4 and putting in the 275R and the noise went away.. just for giggles i put the 275R chip in my 275G4 and it also made the poping sound from the outputs...
Has any one ever tried to copy the PIC16C71 chips from the ORION amps. I have a programmer i need to check to see if it will do pic chips.. But would like some input if you have done this before..
Sam
Old 15th February 2009, 01:40 PM   #2
I do not know if you can burn that chip, but I think they are available. Perry should be able to get you info on obtaining one.
If it ain't broke Don't fix it
Old 16th February 2009, 12:25 AM   #3
The chips are available, but the programming info is not. But since you have the working chip and the programmer, it seems as though you only need some new chips.
Old 16th February 2009, 02:08 AM   #4
Yea i knew i could get the chips.. at one point in the past i used this same chip to make mod chips for playstation 1 so that i could play burnt games...
what i am worried about is.. some pic chips have code that will 0 the chip if it is read in a programmer.. i dont want to make my working amp a door stop by reading the pic.
i was hoping some one else had this problem at some point in time..
Old 16th February 2009, 03:37 AM   #5
Send a message via AIM to DigitalJunkie
IIRC there is also a type of PIC that has "fusible links" inside,that manufacturers can nuke after programming,and prevent the chip/code from being read.
Been a while since I played with PIC's,so it's kinda foggy.
Old 18th February 2009, 06:13 PM   #6
MartyM is offline MartyM  United States
MartyM's Avatar
Send a message via Yahoo to MartyM
You should not have to worry about simply reading a PIC. I've never heard of (or experienced) a microcontroller failing to run after an attempted read assuming nothing else was done incorrectly.
The flash-based PICs/micros today are sometimes funny though.
That PIC is ROM only so it should be safe. However, in a commercial product it's a pretty safe bet the security bits are set and you can't retrieve the .HEX image.
It shouldn't hurt to try.
PS: why are you needing to replace the PIC?
PS2: should be pin-compatible replacement PICs available now
Old 18th February 2009, 06:25 PM   #7
as i said in my first post, i need to replace it because it does not work right. it makes a poping sound when installed in the amp. i have tried swapping it into a my test unit and i get the same poping sound from my know good test unit.. if i put my known good pic from my test unit into the unit that has come in for service the noise goes away.. thus there is a problem with the pic..
i have replacement chips. just need code to load on chip.. the programmer i have will only read 3ffff from the working chip.. i have a new chip programmer on the way as i dont know if my old one is working as it should.
Sam
Old 18th February 2009, 08:10 PM   #8
MartyM's Avatar
Hi, sorry if I misunderstood the original post.
If your programmer/reader is working correctly, and you get "3FFF" on a read, then unfortunately it's locked and can't be read.
Perhaps you could get the .hex file from Orion? Otherwise, maybe make a "saved search" on eBay for it to email you automatically when one pops up there.
Hmm...sorry I couldn't be of more help.
Old 18th February 2009, 08:43 PM   #9
yea i was thinking it was going to be locked.. bummer.. that this is a perfect working amp with a bad pic chip... as the amp will not run with out it...
Sam
Old 19th February 2009, 01:45 AM   #10
Well i take back what i said about the amp not running without the pic.. it seams the amp will run but does not light up the power led.. i all the xovers work high and low.. tomorrow i will check that the bridge and phase switches work. as of right now i do not see any function of the amp loss with out the pic just the power led...
I am thinking that the pic may be for the intelli-q.
Any one have any input?
I will post what i find tomorrow, im calling lights out for tonight.
Orion 275R crossover section Samuel Rock Car Audio 5 19th January 2009 02:14 AM
Orion NT 200 vs Orion 2150 SX Clipped Car Audio 3 12th June 2007 01:55 PM
Orion hcca 275r question Leif Car Audio 2 25th August 2006 12:31 AM
chip amp with Orion speakers ? sl_1800 Multi-Way 10 5th December 2004 12:36 AM
Need help About Orion HCCA 275r Leif Car Audio 1 4th December 2004 01:26 AM
Page generated in 0.10265 seconds (83.30% PHP - 16.70% MySQL) with 10 queries
