I replaced power supply fets and right channnel fets.
The amp powers up and plays ,no fets get hot but r17 gets really hot , can't figure out why. Also the left channel is not as loud as the right, gains are down on both channels. |
#2 |
If C9 isn't shorted and none of the FETs in the power supply are running hot, it's probably normal. They use a large resistor so it can dissipate the heat produced by normal operation. Unless it's getting hot enough to desolder itself, it should be OK.
For the gain problem, check the signal on pin 2 of both driver boards. I think both should have essentially no signal. If one does, the 10uf capacitor may be defective. Many of these caps leaked and caused damage to the board. To see it, you generally have to lift the capacitor.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
I can't believe that the resistor gets that hot, but all the dsm's I have seem to do it.
I have a few leaking caps on this amp, I might as well replace them while I have it apart. |
#4 |
Changed out all the leaking caps and still not any louder on that channel.
#5 |
So you changed the right channel fets and the left channel is the quiet one? Are you sure none of the left channel fets or drivers have an issue? If the left outputs are ok, I'd guess something on a driver board is the issue.
Don't worry... you can always turn the gain down! |
#6 |
I have extra irf540's so I will replace them and see what happens.
#7 |
On pins 17 and 18 of the input board do you have the same signal level?
If you don't have a scope, use a test tone and measure the voltage with your meter (set to AC volts). You stated that the gains were down in both channels. Do you mean the gain control is set to a low level or that there was insufficient gain (less than you'd expect) in both channels? The 540s won't have any effect on the gain.
#8 |
The gain controls are turned all the way down.
I checked pins 17 and 18 and got .563 or so on each pin, don't lknow if I am doing it right tho. I also noticed that when u pull the rca cable out 1/2 way the is no change in volume like most amps. |
#9 |
What about these (AC voltage - with the same input signal you were using before)?
Left channel audio driver board: Pin 1: Pin 2: Right channel audio driver board: Pin 1: Pin 2:
#10 |
Pin 1: .363 Pin 2: .282 Right channel audio driver board: Pin 1: .175 Pin 2:.265 input on pins 17 and 18 of input board are .532 |
| punch 100 dsm question | ben04srt | Car Audio | 32 | 7th December 2009 12:38 AM |
| Selling a punch 250a2, old punch 75, and ppi epx 205 on EBAY | ppia600 | Swap Meet | 0 | 23rd February 2008 01:17 AM |
| Punch 800.2 | meepers | Car Audio | 26 | 16th January 2008 09:32 PM |
| RF Punch 75.2, help plz | JSmooth420 | Car Audio | 5 | 17th September 2006 10:20 AM |
| My experience: the cheap punch set VS Greenlee punch | vax9000 | Tubes / Valves | 5 | 21st July 2006 07:52 PM |
| Page generated in 0.10426 seconds (77.90% PHP - 22.10% MySQL) with 10 queries |
