Go Back   Home > Forums > General Interest > Car Audio
Old 9th February 2009, 11:44 PM   #31
fongman is offline fongman  United States
most of the green one measure .4 and two measure over 100 and the
r325 measure 10 ohm.
Old 10th February 2009, 12:29 AM   #32
on the 101 i get 100.2 on the 1001 i get 998 are these okay
Yes. The ones with 4 digits have 3 significant digits and a multiplier. 1001 is 1, 0, 0 and 1 zero (1000 ohms). They have a 1% tolerance. The ones with 3 digits have a 5% tolerance.
R325 is OK.
The 0.1 ohm resistors that measure 0.4 ohms are probably OK. If you touch your meter leads together, they will probably read 0.3 ohms. You have to subtract that from the actual reading when reading low value components. You must replace at least 5 of the 0.1 ohm resistors. I'd replace them all. The difference in cost won't be significant.
If you buy from Mouser, I'd recommend these:
LVR03R1000FB12
Old 10th February 2009, 12:31 AM   #33
Email me.
babin_perry@yahoo.com
Old 20th February 2009, 05:14 AM   #34
just replace all the parts i got from mouser and now the amp is working. Thanks perry for you help and time.
Old 25th February 2009, 09:27 AM   #35
81300sd is offline 81300sd  United States
Thread hijack.
I just bought a power 1000a2 with one side blown.
Visual inspection shows 10 mosfets blown 10 resistors blown and atleast 2 of the 1001 resistors blown(r355, r385)
Although the graphic posted differs from mine slightly, it seems to be the same monster. Can I assume that I should follow the same procedure?
I may send this to a shop as soldering those little ones scares me.
Old 25th February 2009, 09:44 AM   #36
The procedure is essentially the same. Which 10 resistors are blown?
Old 25th February 2009, 01:59 PM   #37
I actually enjoy doing the work, But its totally up to you.
Old 25th February 2009, 02:53 PM   #38
81300sd:
Can you send me a photo of the inside of the amp?
This may be the same as the 1100a2. If so, it has a completely different audio amplifier section than the 800a2.
If it's like the 1100a2, you'll need to start a new thread.
Old 26th February 2009, 11:40 AM   #39
Well I got a schematic from Rockford for the 1000a2 and its for a 1100a2 so I am guessing its the same as the 1100a2
Heres a pic of the bad section. Everything with red arrows is confirmed dead.
Old 28th February 2009, 08:35 AM   #40
Thank You Perry Babin by finding thread on the 800a2 i was able to the figure out the problem and get my amp back working all the parts that you told the other guy to check was also bad in my amp Thank You again.
rockford fosgate 1500 bd mike49504 Car Audio 18 30th December 2008 07:37 AM
Rockford Fosgate 325.1 phreaktor Swap Meet 1 28th February 2008 11:54 PM
rockford 800a2 fried channel help . ethridgeruby Car Audio 3 27th July 2005 06:09 PM
rockford 800a2 fried channel help . ethridgeruby Solid State 1 22nd July 2005 08:02 AM
New Rockford Fosgate amp. $50.00 NerdMike Swap Meet 0 4th March 2005 11:57 PM
Copyright ©1999-2013 diyAudio
