Rockford fosgate 800a2
Old 9th February 2009, 08:22 PM   #21
fongman is offline fongman  United States
pull Q329/30/24/25 and r364 off
r334: 20.5 ohm
r335: 20.5 ohm
r362: 20.5 ohm
r363: 20.5 ohm
out put speaker is 41v
how is it higher now?
Old 9th February 2009, 08:29 PM   #22
Perry Babin is offline Perry Babin  United States
A leaking output transistor is probably causing the output to be driven toward the rail.
Old 9th February 2009, 08:44 PM   #23
i don't know if you catch the post on eariler but i left 3 irf640 on the board? would that make different?
q218,19,20
Old 9th February 2009, 09:02 PM   #24
At this point, none of the outputs need to be in the circuit. They weren't cut loose from the circuit at first to allow you to determine if the drive circuit was intact. Now that you know it's damaged, they can be cut out of the circuit so you can check the rest of the components.
Remember to remove the 0.1 ohm resistors also so they don't interfere with the other components.
With those components out of the circuit, you should read the correct value for most of the rest of the resistors. The value is printed on the top of the resistor. The first 2 digits are the value. The 3rd digit is the multiplier. 101 = 1,0 and 1 zero (100 ohms). 510 is 51 and no zeros (51 ohms).
Old 9th February 2009, 09:57 PM   #25
cut those 3 and now .014v on both speaker output. I think it okay now?
which 0.1 ohm resistors are your referring to?
Old 9th February 2009, 10:12 PM   #26
Well... It's not OK. It simply doesn't have 30+v on it.
The large green ones that you've been reading 0.4 across.
Old 9th February 2009, 10:19 PM   #27
I still have 5 on the board. should i take them of too?
Old 9th February 2009, 10:28 PM   #28
Yes.
Old 9th February 2009, 11:22 PM   #29
okay now with them off i measure
r333,r334 is 200 and i measure 20 ohm so it should be fine?
r328,r329 1001 and i measure 999 ohm looks okay?
r355,r356 1001 and i measure 999 ohm looks okay?
r362,r363 200 and i measure 20 ohm looks fine?
r377 510 and i measure 51 ohm
I'm checking the rest and see if there are any bad one.
Old 9th February 2009, 11:29 PM   #30
on the 101 i get 100.2
on the 1001 i get 998
are these okay
Rockford fosgate 800a2Hide this!Advertise here!
rockford fosgate 1500 bd mike49504 Car Audio 18 30th December 2008 07:37 AM
Rockford Fosgate 325.1 phreaktor Swap Meet 1 28th February 2008 11:54 PM
rockford 800a2 fried channel help . ethridgeruby Car Audio 3 27th July 2005 06:09 PM
rockford 800a2 fried channel help . ethridgeruby Solid State 1 22nd July 2005 08:02 AM
New Rockford Fosgate amp. $50.00 NerdMike Swap Meet 0 4th March 2005 11:57 PM
