Rockford fosgate 800a2
Old 9th February 2009, 08:50 AM   #11
fongman is offline fongman  United States
R337: 100 ohm
R338: 47 ohm
R339: 100 ohm
Old 9th February 2009, 09:00 AM   #12
Perry Babin is offline Perry Babin  United States
Those are OK.
You stated that it powered up OK. When powered up, did it have any DC voltage across the speaker terminals?
Old 9th February 2009, 09:02 AM   #13
yes, I think it was 47v or 37v.
Old 9th February 2009, 09:06 AM   #14
If it has more than ~0.05v DC across the speaker terminals with the blown parts out of the circuit, it has more serious problems. You need to check all of the parts (the ones you haven't checked as of yet) that have green arrows in the photo.
Old 9th February 2009, 09:13 AM   #15
with the resistor out i will power up again and let you know in morning. Thanks perry.
Old 9th February 2009, 06:25 PM   #16
The R channel is 34v and the L channel is 0v. I will have to check all the other parts. What should i be looking for on the other parts?
Old 9th February 2009, 06:34 PM   #17
With a high power lighted magnifying glass, you can look for a bubble or other defect in the center of the top surface of the SMD resistors (see attached). Also look for signs that the solder overheated on them. Those will likely be defective.
You will also need to replace the MPSA06 and MPSA56 driver transistors. Even if they check OK, replace them. If they're leaking and you power up the amp with the new components, they will cause the outputs to fail again.
Old 9th February 2009, 07:23 PM   #18
r334:20 ohm
r335:10 ohm
legs 1 to 2
q324:3.2ohm
q325:3.5ohm
legs 2 to 3
q324:2.5 ohm
q325:3.5ohm
r328:994 ohm
r355: 991 ohm
legs 1 to 2
q329: 4.8 ohm
q330:180.5 ohm
legs 2 to 3
q329: 998 ohm
q330:3.5
r362: 20 ohm
r363: 20 ohm
r378: 51 ohm
r364: 10.1 ohm
r366: .4 ohm
r368: .4 ohm
r370: .4 ohm
r372: .4 ohm
r374: .4 ohm
looks like the r364 is bad also?
Old 9th February 2009, 07:39 PM   #19
i can't seem to locate MPSA06 and MPSA56?
Old 9th February 2009, 08:14 PM   #20
Q329/30/24/25 are the MPSA06/56. Pull them out of the circuit and recheck the resistors near them.
Also pull the 0.1 ohm resistors. That will allow you to more accurately read the value of the resistors like R364.
Thanks for taking the time to post the results in a way that's easy to read.
Rockford fosgate 800a2Hide this!Advertise here!
rockford fosgate 1500 bd mike49504 Car Audio 18 30th December 2008 08:37 AM
Rockford Fosgate 325.1 phreaktor Swap Meet 1 29th February 2008 12:54 AM
rockford 800a2 fried channel help . ethridgeruby Car Audio 3 27th July 2005 07:09 PM
rockford 800a2 fried channel help . ethridgeruby Solid State 1 22nd July 2005 09:02 AM
New Rockford Fosgate amp. $50.00 NerdMike Swap Meet 0 5th March 2005 12:57 AM
