Go Back   Home > Forums > General Interest > Car Audio
Old 30th January 2009, 08:14 PM   #1
Default punch 100dsm help
I am having trouble find out why I have no power on this thing.
The ps fets were replaced first and the outputs checked out ok.
Do the pwm chip go out on these often?
I have no leaking caps , already checked that.
Old 30th January 2009, 08:24 PM   #2
Post the DC voltage on all of the pins of the TL494 driver IC.
(copy and paste this into your reply)
Pin 1:
Pin 2:
Pin 3:
Pin 4:
Pin 5:
Pin 6:
Pin 7:
Pin 8:
Pin 9:
Pin 10:
Pin 11:
Pin 12:
Pin 13:
Pin 14:
Pin 15:
Pin 16:
Old 30th January 2009, 08:25 PM   #3
BEAR-K is offline BEAR-K  Canada
Default dead 100dsm
That series of Fosgate amps used a daughter board as the power supply pwm oscilator & driver to the FETs. These were
most often the culprit. The boards have been out of production
and out of stock a number of years. At our service facility we were
never able to repair the daughter boards as it meant soldering to
a pad on a ceramic surface. Perhaps someone else had sucess.
Bear-k
Old 30th January 2009, 08:37 PM   #4
I think this is the board he has:
http://www.bcae1.com/temp/img372rock...rsupplyold.jpg
Old 31st January 2009, 05:37 AM   #5
I have no power on the tl594c at all
Pin 1: 0.00
Pin 2: 0.00
Pin 3: 0.90
Pin 4: 0.00
Pin 5: 0.00
Pin 6: 0.00
Pin 7: 0.00
Pin 8: 0.00
Pin 9: 0.00
Pin 10: 0.00
Pin 11: 0.00
Pin 12: 0.00
Pin 13: 0.00
Pin 14: 0.00
Pin 15: 0.00
Pin 16:0.010
Reflowed the solder on the vertical board , didn't help.
I have power up to the board then nothing to the ic.
Old 31st January 2009, 08:34 AM   #6
You probably have a broken connection on the remote terminal of the amp.
Old 31st January 2009, 11:53 AM   #7
Ben, when you said you have power up to the board, were you talking about up to the vertical board, or did you mean the mainboard?
If it ain't broke Don't fix it
Old 31st January 2009, 01:23 PM   #8
I have power up to the vertical board.
Is the remote wire what supplys power to the IC?
Old 31st January 2009, 02:02 PM   #9
Remote voltage goes into pin 8 of the driver board (counting left to right, looking at the component side of the driver board), through a diode (4th black component from the left on the bottom row in the photo I posted) and then to pins 8, 11 and 12 of the 494. The voltage goes into the top terminal of the diode and exits from the bottom right terminal.
Old 1st February 2009, 01:03 AM   #10
The diode is bad , power in no power out.
I have some A7 diodes from old punch 45hd boards will that work ?
I think the one that is on there is A7c maybe.
Selling a punch 250a2, old punch 75, and ppi epx 205 on EBAY ppia600 Swap Meet 0 23rd February 2008 01:17 AM
Punch 800.2 meepers Car Audio 26 16th January 2008 09:32 PM
RF Punch 75.2, help plz JSmooth420 Car Audio 5 17th September 2006 10:20 AM
My experience: the cheap punch set VS Greenlee punch vax9000 Tubes / Valves 5 21st July 2006 07:52 PM
Page generated in 0.09065 seconds (80.30% PHP - 19.70% MySQL) with 10 queries
