I want to build an isobaric encloser for 4 12" hifonics hfi12d4
The box per sub is 2 cubic ft ported So my question is if i want to do an isobaric box for the 4 subs what size box would i need to build so i can run 4 subs isobaric any help would greatly be appericatred the specs for the sub is fs=27.0hz qms=7.720 vas=8.300 cu ft cms=104.905 in lb. mms=2.010 oz xmax=0.169 in sd=80.5 square in dia=10.1 in qes=0.570 re=4+4 ohms le=1.1mH pc 300.0 watts |
#2 |
I installed one of these subs in my friends Passat.
Put it in a bass reflex enclosure that I built (2.5 cu ft tuned to 35Hz) and it slams off 200 watts. Smooth and slams the lows. Per sub I would recommend between 2-2.5 cu ft tuned between 30-35Hz. you sure those specs are correct? So for a pair of Isobaric drivers I'd recommend between 1-1.25 cubic feet net per driver tuned between 30-40Hz depending on your style of music |
#3 |
Thoose arent the right spec's for the subs sorry.
The sub calls for a 1.75 cubic ft box per sub. So wondering if i did an isobaric box ported what size box would i need to build . |
#4 |
If 1.75 ft^3 is appropriate for a single sub, then each isobarik pair would need to be in half of that for equivalent performance.
That's 0.875 ft^3 or what, about 1500 cubic inches? Be sure to add in the speaker displacement, it gets significant for large woofers in such a small enclosure. Do you need to use an isobarik system to reduce box size, or just want to do it for the fun?
Tim |
#5 |
space is an issue. Also the speaker will work in a 1.25 cubic ft sealed encloser per sub. wondering if i do the 1.25 cubic ft per sub will it hit the low's or would a ported iso box work better
#6 |
Ported is better...isobaric is fine...just take the size for two subs and cut that in half.
Only thing with isobaric ported enclosure is that the port will be very long for the proper amount of port area. Sealed will work...I'd try that out first |
#7 |
i decided to built the iso baric box. So if i build the box to around 1 cubic ft per sub should i be fine. they call for a 3" port 5" long in the 1.75 cubic ft box so if iso baric wondering anyone know what size the port should be any help would greatly be appericated
| Subwoofer out question. | G | Tubes / Valves | 2 | 6th February 2008 05:28 PM |
| First DIY Subwoofer, Amp question | Lokalazeros | Subwoofers | 36 | 24th January 2008 03:10 PM |
| Another which subwoofer question... | RockysDad | Subwoofers | 17 | 15th October 2006 01:46 PM |
| Subwoofer Amp Question | samsagaz | Solid State | 0 | 10th September 2004 05:38 PM |
| pro-subwoofer question | trespasser_guy | Subwoofers | 5 | 1st March 2003 01:30 PM |
| Page generated in 0.09261 seconds (75.21% PHP - 24.79% MySQL) with 10 queries |
