Can I use car tape player output for recording?
Old 20th January 2009, 05:16 PM   #1
rapjp is offline rapjp  United States
Default Can I use car tape player output for recording?
All,
I am thinking of purchasing a Nakamichi car tape (TD-700) player for archiving some of my tapes as it has azimuth adjustment.
That said, since I do not have the player with me yet, I wanted to ask - what kind of output does the TD-700 produce? Can I use the output directly as a "line level" input to a digital recorder (Edirol R-09) OR do I need to feed it to some home amp and then use the the home amp line level output for feeding to my digital recorder.
I know home stereos run on 8 Ohms while car stereos run on 4 Ohms, but that is for output sent to the car speakers...Does the TD-700 have other kind of output as well?
My issue is that I want to use the Nak deck to playback (power by a DC power supply) and want to directly capture the output into my Edirol R-09 recorder.
Is this at all possible...I am new to car audio and wondering if my theory will work or not...And not knowing what outputs the TD-700 has is making it harder for me to know.
Please help!
Old 20th January 2009, 05:37 PM   #2
HK26147 is offline HK26147  United States
If it has a line level output ( 2V or less approx. ) yes.
If it has RCA output jacks, yes
If it is a powered output designed to be attached directly to speakers NO
Old 20th January 2009, 10:21 PM   #3
tsmith1315 is offline tsmith1315  United States
tsmith1315's Avatar
The TD700 is preamp level only, switchable 500mV or 1000mV. You should be able to run it directly into the recorder.
Beware that it's not really a "line level" because it runs through the volume control. If you're going to be recording from it, be careful not to disturb the volume knob.
The preamp is pretty clean, I've been able to use mine at full volume without noticeable distortion.
Tim
Can I use car tape player output for recording?Hide this!Advertise here!
Anyone still make a good Walkman tape player? johnr66 Analogue Source 2 30th January 2014 04:07 PM
Tape decks for recording bands on, what's a good one? Test Electrix Analogue Source 3 15th April 2009 04:59 PM
Fixing Audio Cassette tape player peterlo Everything Else 4 19th June 2007 08:49 AM
Is Analog (tape recording) Dead? jcx Everything Else 4 21st January 2005 12:49 PM
Tape Output to Subwoofer s0rce Subwoofers 8 19th January 2003 02:24 AM
Copyright ©1999-2017 diyAudio
