Go Back   Home > Forums > General Interest > Car Audio
Old 9th January 2009, 04:32 PM   #1
Default slot port Q
Im planning out my next box. just want opinions. I need ~25 square inch port. would it sound any different doin a 5*5, or a 4*6 or a 3*8 inch port?
Old 9th January 2009, 05:37 PM   #2
jol50 is offline jol50  United States
Not that I know of, but if you are going with a high excursion sub bigger seems to work better. Well if you beat on it that is.
Old 11th January 2009, 05:05 PM   #3
one other thing do you count the thickness of the face of the box in overall lenth? i will be posting my box design soon.
Old 11th January 2009, 06:13 PM   #4
Internal airspace should be only inside the box measure, actually minus the space the rear of sub and port takes up as well. Unless it is a pre-designed box with part size listed.
Old 11th January 2009, 09:17 PM   #5
so port lenth is only behind the baffle?
Old 11th January 2009, 10:13 PM   #6
That was box area I must have misread. Port length is the total inside length of port from open space inside to open space outside. If you taper the ends you only count part of the taper, IIRC less than half. There are a pile of box building sites that can figure it for you, or I just use winISD.
Slot port vs circular port equivalence Brisso57 Multi-Way 12 21st February 2009 02:38 PM
Folded Slot Port diesel_88 Subwoofers 4 5th June 2008 12:35 AM
Slot Port in Corner? Alero Subwoofers 1 20th November 2005 11:12 PM
Would this work - Karlson + slot-loaded port DeonC Subwoofers 27 26th September 2005 07:11 AM
Slot port help Javaman Subwoofers 6 9th March 2002 07:53 PM
Page generated in 0.08466 seconds (70.85% PHP - 29.15% MySQL) with 10 queries
