Go Back   Home > Forums > General Interest > Car Audio
Old 5th January 2009, 10:38 PM   #1
Default Quieting Noisy toroid on Xtant Amp
Hello All,
Happy New Year,
I have a quick question. I have an Xtant 403a that emitting a high pitched noise from the torroid. I know I read a post on using some epoxy to quiet them down but I can not find it. I did find a post discussing the use of super corona dope but the instructions for the product require curing after application at about 200f. Anyone have any recommendations on what to use?
thanks,
KC
Old 5th January 2009, 10:49 PM   #2
Can you quiet the noise by touching the windings?
Old 5th January 2009, 10:58 PM   #3
I can quiet it down if I push on it or push down on the front of the board.
Old 5th January 2009, 11:29 PM   #4
Before applying anything to the windings, try moving individual windings to see if you can stop the noise.
You don't want to cover the entire transformer with epoxy (or any other fixative) so you need to try to determine which windings are causing the noise. Then you can apply epoxy only to the point where it's needed. If you can simply move the windings to stop the noise, that would be the best solution.
Old 5th January 2009, 11:42 PM   #5
KOA is offline KOA  United States
another less permanent material than epoxy would be rtv silicon. Ends up like bathroom caulk consistency when done curing. I concur with putting some goo on it. The real deal is to lacquer the inductor(same material they would use from the factory I think). I had a few rockford fosgate amplifiers play the music signal out of vibrating the inductor.
Old 5th January 2009, 11:45 PM   #6
Thanks Guys!
I'll report back on my efforts.
KC
Old 6th January 2009, 01:43 AM   #7
I think I found it. Touching many of the windings merely changed the tone but I did find one that would make it go away and slightly bent it until the noise stopped. In the process of doing this I could see where some enamel was applied to this winding and many of the smaller ones beneath it. I'm going to let the amp sit in the cold overnight since the cold temps seem to be connected to the noise popping up. If I still have noise in the morning I will move the winding a RCH more.
thanks again!
KC
Old 6th January 2009, 01:54 AM   #8
Default might be a fuss but...
if you can remove the transformer you could give it a soak in diluted lacquer. If the lacquer id dilute enough it should soak into and inbetween the windings then you can hang it up to drip dry and that should lock all the windings together and stop the buz.
moray james
xtant 604 x mike49504 Car Audio 8 29th November 2008 09:00 AM
xtant a2002 amp genes66 Car Audio 3 26th February 2008 08:48 PM
Trade a 40V 400VA Toroid for 20V 300VA Toroid john65b Swap Meet 7 10th October 2006 04:49 AM
noisy noisy noisy noisy noisy tube dsavitsk Tubes / Valves 50 20th February 2006 05:07 PM
Quieting down PC eRiCdWoNg Everything Else 19 14th October 2004 07:42 PM
Page generated in 0.10376 seconds (74.65% PHP - 25.35% MySQL) with 10 queries
