Go Back   Home > Forums > General Interest > Car Audio
Old 2nd January 2009, 02:08 AM   #1
Default Smoking Resistor?
Hey Guys,
I'm stumped and hope that someone might be able to lend some knowledge here. I just finished restoring a 1964 Ford Truck transistor radio (model 4TBT) manufactured by Bendix.
I removed the output transistor to clean the aluminum heat sink and repaint the chassis. When I put it back together and went to test the radio the wire-wound resistor (R32) shown in the schematic began smoking. What could be the cause of this?
I would be grateful for any help.
Thanks!
Old 2nd January 2009, 02:32 AM   #2
A shorted C1 or a short to ground on the wire labeled 15.
If it ain't broke Don't fix it
Old 2nd January 2009, 03:01 AM   #3
Thanks for the help. I appreciate it.
I checked the #15 wire and that's good. I suppose I'll need to replace the electrolytics in the can.
Is there any chance it could be wire 13 pictured below? I had to remove that one (to the base of the output) to remove the cover.
Old 2nd January 2009, 03:44 AM   #4
Send a message via AIM to DigitalJunkie
Wire 13 looks like the NFB loop,Unlikely that it caused the problem.
I'd probably start with replacing the filter caps,they are due for replacement anyways.
Old 2nd January 2009, 04:01 AM   #5
Thanks DJ and true, they should be replaced. What I don't understand is why that resistor was fine before I removed the output then once I replaced it the resistor smoked. Is it possible that I did something to cause a short?
Old 2nd January 2009, 04:03 AM   #6
Yea,that's kind of odd.
Was there a mica insulator on the transistor,that got forgotten when it was re-assembled? (Don't worry,we've all done it at least once!)
I Dunno.
Old 2nd January 2009, 04:07 AM   #7
[QUOTE]Originally posted by DigitalJunkie
[B]Yea,that's kind of odd.
Nope. The transistor is a PNP germanium transistor. I made sure I wired them correctly too when I replaced the emitter and base wires. I checked for any grounding and all was good.
Old 2nd January 2009, 09:38 AM   #8
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
maybe you could have just shaken the dried up electros and the metal flakes (which used to be the electrodes) inside the cap and connected both terminals together internally? could be a possibility.
Old 2nd January 2009, 12:20 PM   #9
That makes sense since the caps are almost 45 years old.
I'm going to pull the can today and replace the caps. That will narrow it down.
Old 2nd January 2009, 03:25 PM   #10
I know it's not C1 because I just replaced the caps with the same result (smoke). I checked the connections and replaced the output transistor and it's still smoking. Any ideas of what should I try next?
Zen V4 Smoking Q5 Diomedian Pass Labs 6 15th November 2005 02:46 PM
Power Resistor Smoking on HF-81 HolyGhostFire20 Tubes / Valves 14 12th August 2005 04:48 AM
amp smoking biznatcher Car Audio 5 13th September 2004 11:48 PM
Smoking Amp jkramer Solid State 15 28th August 2004 04:17 PM
DOZ smoking? Kari Solid State 8 1st February 2004 02:40 PM
Copyright ©1999-2013 diyAudio
