Go Back   Home > Forums > General Interest > Car Audio
Old 1st January 2009, 12:06 PM   #1
Bertje is offline Bertje  Netherlands
Default Noise from Ground Zero GZPA1.5000SPL
I have this class D poweramp for repair here.
When turn on with just a speaker connected, without RCA, I can here a lot of noise. From SMPS??
Everything else is working OK, delivers al lot of power.
Idle current is 3,5-4A
Output filters are OK.
http://www.magma-audio.nl/view.asp?ID=163
Any suggestions?
Rob.
Old 1st January 2009, 12:25 PM   #2
luka is offline luka  Slovenia
luka's Avatar
Send a message via MSN to luka
what noise? from where? inside of amp? from speaker?
home page @ http://www.classdaudio.co.cc @ 24/7 all year long
I FEEL SLOVENIA
Old 1st January 2009, 01:25 PM   #3
From the speaker, high frequenty noise. The SMPS itself is quiet and is working normal.
I measured at the primary side squarewaves with a little overshoot, I think it's normal.
Rob.
Old 2nd January 2009, 12:15 AM   #4
luka's Avatar
Small sinewave on output is normal [this is how D amps works], few Vpp at some high freq., @ what amp works, say about 100kHz or so [output stage]...
You can check this before output inductor... you have two, since this amp is bridge already if i'm not mistaken...
I FEEL SLOVENIA
amp with very low ground noise kenny12 Chip Amps 11 28th June 2009 01:49 PM
Very Bad Ground Noise - No Music kdhorne73 Car Audio 9 4th August 2008 08:48 PM
DAC Ground Plane Noise Reduction? fastcat95 Digital Source 1 3rd May 2005 06:08 PM
USB noise (noisy ground) Flemming J P Digital Source 5 9th February 2004 03:57 AM
Page generated in 0.07504 seconds (67.40% PHP - 32.60% MySQL) with 10 queries
