Go Back   Home > Forums > General Interest > Car Audio
Old 31st December 2008, 07:53 PM   #1
Default hakko desoldering gun question
On my hakko desolder gun the heating element wires came unsoldered so it dont heat up.. Wondering can i use the same solder to re attach the wire the came unsolderd or do i need a speical solder since the element heats up
Old 3rd January 2009, 05:55 PM   #2
I have owned several of the desoldering stations over the years, and have repaired a lot of them too.(metcal, peco, RFI, ect...) I have always used regular solder when repairing the heating elements, EXCEPT when it is touching the heating element. Then you would have to tack-weld the connection. Not solder. There are only those 2 types of connections inside the irons. Solder or tach/spot weld... Post a pic, and it would help me or others figure out which piece you are wanting to repair...
Old 4th January 2009, 08:20 PM   #3
Crimp if you can, but as tomtomjr said, you'll probably need to tack/spot-weld the wires on.
- Adam
Desoldering tools Zero Cool Everything Else 3 7th January 2007 11:49 PM
Hakko Question bigmike216 Parts 1 26th June 2005 09:09 AM
desoldering station audio-kraut Equipment & Tools 1 13th June 2005 10:45 AM
Recommendation for desoldering guns Sunsun22 Parts 1 16th July 2004 12:52 AM
Hot air tip- Desoldering SMT parts Dave Everything Else 10 1st February 2003 12:44 AM
Page generated in 0.06273 seconds (68.72% PHP - 31.28% MySQL) with 10 queries
