Go Back   Home > Forums > General Interest > Car Audio
Old 25th December 2008, 03:11 AM   #1
Bom is offline Bom
Default fixing Orion GS1000
In my GS1000, it uses 10pcs of SJE2889 transistors in power stage and 12 pcs of 2n6491 in output stage. They are all Motorola. I can't find these transistors on the net. DO you have any suggestion anywhere I can buy them? Or any transistors with better spec to replace original parts?
thank you,
Old 25th December 2008, 05:01 AM   #2
Post a pick of the "Power stage" and the "Output stage" please as I recall these were simple class AB amps and that means matched P&N power devices through out the amp.
The match to 2N6491 is 2N6488 for your output stage. Driver stages for these amps were MPSU-06 and 56 or CEN-07 and 57 devices typically, so you other part number is puzzling and its location on the board probably will lend a clue to its ID and purpose....Merry Christmas
Old 25th December 2008, 05:54 AM   #3
E2889 > 2N6488
Old 26th December 2008, 05:50 AM   #4
Send a message via ICQ to Samuel Rock Send a message via MSN to Samuel Rock
Findchips.com to get your outputs.. and also mouser has them in stock btw... i just order 100 of each 2n6488 and 296491 from them.
If the drivers are bad you are going to have some trouble getting them. i have a 2250 that is inneed of the drivers now.. perry has a combo that he has been uising with no problems..
Sam
Old 27th December 2008, 03:58 AM   #5
Clipped is offline Clipped  Thailand
Send a message via MSN to Clipped
Default Re: fixing Orion GS1000
thank you,
you wont find the 2n6488 or 2n6491 in ban moh or any other electronics parts supplier in thailand.
give me a call at 086-977-4077 and i will sort you out.
im in the srinakarin area.
Fixing the R30 bjackson Multi-Way 3 16th May 2010 06:10 AM
Orion NT 200 vs Orion 2150 SX Clipped Car Audio 3 12th June 2007 01:55 PM
Need Help Fixing an old NAD 304 li_gangyi Solid State 14 8th December 2004 07:59 PM
Help! Fixing Amp. shajan Solid State 20 29th May 2004 08:06 AM
Page generated in 0.08580 seconds (79.51% PHP - 20.49% MySQL) with 10 queries
