Hi All,
Can anyone help me to use this N-Ch-Mosamp schematic in car amp, I dont know does it work ? Or any modification in the schematic than suggest. Regards
ssmir |
#2 |
Hi
Where is the schematic? |
#3 |
HI Anthony
Any help ?
ssmir |
#4 |
Hi Again
Your schematic looks like a Class-D amplifier if I am not mistaken. The only thing you really need is a suitable Switchmode power supply www.coldamp.com have suitable power supplies on their site. However this amp of yours requires 3 supplies. Try linking the 79 volt supply via a power diode to the 100 v rail and run the whole lot from a +-80 volt rail. This only leaves the +15 volt logic supply to worry about. As I mentioned above one of coldamps SMPSs would do the trick. |
#5 |
Hi Anthony
Thanx for reply but SMPS is not worry if amps schematics is properly working
ssmir |
#6 |
HI,
Change the think of amp and finely this design is ok its my thouth because this tested by my friend and now i will design pcb for it please send you all veluable suggetions Best Regards
ssmir |
| BiCMOS Bipolar+MOSFET better than MOSFET | lineup | Solid State | 5 | 8th December 2009 11:46 AM |
| New mosfet amp from ESP | B.VDBOS | Solid State | 139 | 2nd July 2004 03:18 AM |
| MOSFET/MOSFET amplifier | jarek | Pass Labs | 21 | 22nd June 2004 05:04 PM |
| The best Mosfet for the ZOZ ? | ralf | Pass Labs | 6 | 9th January 2002 05:41 PM |
| Page generated in 0.09243 seconds (76.65% PHP - 23.35% MySQL) with 11 queries |
