#11 |
After a thorough inspection, I realized one emitter resistor had broken it's solder joint. There were three bad output transistors on that same side. What happens when the emitter resistor becomes disconnected?
Re-soldered resistor, replaced the outputs plus the vented cap and all is well again. |
#12 |
When the eimitter resistor loses it's connection, it essentially removes that particular transistor from the amplifier. If the amp has 3 positive and 3 negative outputs, and one emitter resistor fails or is disconnected, now you have 3 and 2. It wil put more of a load on the 2 that are still in the circuit.
If it ain't broke Don't fix it |
| Audiobahn A16000V amp in Protection | adelphia83 | Car Audio | 114 | 25th October 2008 10:10 PM |
| My 2+1 project; FAILED! | Dxvideo | Chip Amps | 37 | 3rd March 2008 06:15 AM |
| another failed gainclone | theChris | Chip Amps | 23 | 20th July 2004 07:23 PM |
| Page generated in 0.06687 seconds (68.66% PHP - 31.34% MySQL) with 10 queries |
