hifonics zeus xi - Page 7 - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 8th February 2009, 02:12 AM   #61
I found a bad op-amp , blown resistor, and a cap that vented through the bottom couldnt see it before so hopefully this cures the problem i let u know thanks for all the help
Old 8th February 2009, 03:35 AM   #62
DO you know where i might be able to buy a couple of the dtc343tstp the ones i need are leaded not surface mount checked digikey mouser mcm cant seem to find a place to buy them or is there a good cross
Old 8th February 2009, 03:55 AM   #63
They were used in Autotek and Hifonics amps. If you have any junkers laying around, they're likely to have them.
If you don't have any and can't find a source, a 2SD1302 with a 4.7k ohm series base resistor may do the job.
Old 8th February 2009, 07:40 PM   #64
I was looking at the pwm board in this amp again while putting it back together. looks like someone put in a new timing cap for the 494 they put in a 1pf cap marked 102 its connected to pin 5 of the 494. Wondering if this value isnt right would it have anything to do with the left channel working and the right channel dead.
Just wondering before i go putting this thing back together and being frustrated when and if it doesnt work
Old 8th February 2009, 07:52 PM   #65
1-0 and two zeros in picofarads = 1000pf
That's a relatively common value for the power supply timing capacitor. If that was the problem, the symptoms would have likely been failing power supply FETs. It couldn't cause a dead channel unless there were two power supplies (one for each channel) and they had their own power supply driver IC.
Old 9th February 2009, 04:10 AM   #66
Ok think i finally found one last problem with this amp.
I found a bad solder connection on the speaker terminal block .
So theres no connection between the terminal block and the rigt channel.
But as my luck would have it my desoldering gun took a crap heating element went bad. so when i get the new one ill finish putting this thing together and let you know
Thanks again
Old 9th February 2009, 05:20 AM   #67
It's generally difficult to get solder to stick to the terminals after the solder connections fail. The best option is to copper plate them. If that's not possible, you may have to drill through the board so that you can solder a wire along the top of the terminal where it 'may' accept solder. Solder it quickly. It takes very little time to damage the coating. If that fails, you can drill and tap and use a screw to hold the wire to the terminal (similar to the one below).
Old 12th February 2009, 06:22 PM   #68
I wanna THANK you for all your help Perry.
Im waiting on the muting transistors but replaced some diodes and opamps.
Just powered the amp up on bench and its working !00% Thanks again
Old 12th February 2009, 06:23 PM   #69
thats 100% working
hifonics zeus vii mike49504 Car Audio 6 30th April 2012 06:31 PM
hifonics zeus VII stuck on pause amc32 Car Audio 1 10th April 2008 08:41 AM
Hifonics Zeus Series VII Busted resistors drumheadz Car Audio 1 6th June 2007 05:00 AM
Need help identifying an early hifonics Zeus jeclute Car Audio 4 5th June 2007 08:05 PM
Hifonics Zeus VII redimp Car Audio 1 20th December 2006 11:47 PM
Copyright 1999-2017 diyAudio
