#21 | ||||
Volume means almost nothing to me without clarity. Bass is the hardest end of the sound spectrum to shape and analyze so I dont expect perfection in my car. Quote:
[thanks for pushing that Earthquake ppia600 ] I know you said that you usually end up swapping and mixing and matching to find the best fit but if you were to pick between those 2 which would it be? They are the same price within 5 dollars and both with free shipping. Quote:
#22 | ||
You can run into an issue with too big an amp on IB subs they can get more dynamic. That means a peak in the bass can generate a lot of excursion even though listening level is not that high. This seems to be more of an issue with light duty subs that bottom easily. I don't use many expensive subs for IB I try to run more of them instead, in fact these infinity are most HD I have run IB. I mean if you think you might get a box later and need a larger amp, you could get it now. I don't think of it because I have 250/350/400/600/850/1kw rms class D amps sitting here, I could even strap two of the 1kw but never will. So far the newer amps I have listened to all have a flat curve, older amps may not. Maybe someone else can chime in on amps. I work on them some now but still learning about quality and such. My issue is how they distort on mid/highs. Sub amps I don't worry about the sound that much either they have the power or not....but all that leads me right back to where I always been--try it and see. At least with a tweeter you have an idea of what one is brighter than another. Quote:
Like I said before mine is a little much and I did it to get db at 20Hz. It will blow me out of the car at 50Hz, my xover is at 45 and my EQ is -4db at 50. I want to swap to pair of moderate 15s, should still get 20Hz and give me more amp room, less weight. I will try a pair of cheap 15s first to see if they can do it, in fact will build the baffle to port the whole trunk to 20hz just for fun as that models to give way more output down there. If it worked I could use less power, but we will see and I'd have to deaden my trunk some. I have a little 350rms class D that would be perfect if it works, or could use about any amp really at that power level. Getting a lot out of a little is great fun when I have the time to play. |
#23 |
/\ The amp I linked is used, not new. It is also a high quality amp with great damping, which is an important spec when running IB setups. More amplifier damping = better. He can always turn the gain down (like it says below \/ ) It doesn't hurt to have more clean rms power than you need. This way you can push the speakers to their usebale limits without any amplifier clipping.
Ok, the earthquake auction ended with "buy it now". My audio bug was actually trying to coherse me into buying it just in case, lol. Good thing someone else grabbed it
Don't worry... you can always turn the gain down! |
#24 |
I looked at it, that is a lot of cash for a scratchy thing but I guess it is a big USA amp. I have a 880rms sounstream sitting here I wish would fetch me that much.
#25 |
$175 a lot of cash for a good amp?
Wow, then I really paid too much for my art amps... and they are only 600 watts rms. And the amp wasn't in bad shape, but a few scratches shouldn't matter to someone looking for sound quality and build quality.
#26 | |
Its late and i'm really tired , I'll be back tomorrow, i can't think very clear right now
#27 |
Hey these amps have their values, I am not familiar with that brand. I assume it is a PPI amp? Look what people pay for LP....has little to do with their real world performance as an amp. Thing I didn't like is the rust on the ends, or what looks like rust. Most of these old amps that are rough go for half what a nice one goes for, but I have no idea what ppi 2150 are worth I was never into ppi.
#28 | |
ppia600, do you know? Supply caps look like those in my Autotek 7600BTS.
Tim |
#29 | ||||||
![]() Quote:
Thanks!!!
#30 | |
What should I do to refurbish those rusty looking connections? |
| Best combo 4 car | kensr05 | Car Audio | 4 | 24th March 2006 06:45 AM |
| Enclosures for Eminence Sigma 18" and/or Eminence Kilomax 15", PA-sub application | esaias | Subwoofers | 8 | 10th August 2005 05:17 AM |
| GC + dvd combo | rs1026 | Chip Amps | 4 | 8th March 2005 08:35 AM |
| best sub + amp combo? | Xplorer | Car Audio | 2 | 13th June 2004 10:12 PM |
