kicker DX700  problems
Old 3rd November 2008, 09:24 PM   #1
ben04srt is offline ben04srt  United States
Default kicker DX700 problems
I bought this amp awhile ago on ebay, and finally tried messing with it.
The problem is I can only get sound if I ground the rca's to the case.
Old 3rd November 2008, 09:38 PM   #2
1moreamp is offline 1moreamp  United States
Try looking under the board for a Pico fuse or a open SMD cap in the RCA ground trace. This is a very common problem on this era of Kicker amp especially after the amp has been abused and over driven into clipping. Hope this helps
Old 3rd November 2008, 10:29 PM   #3
If the Pico fuse only has the letters TH than that is my problem.
Might there be a way around that, or is that to keep from wiping out the whole preamp section.
Old 4th November 2008, 01:14 AM   #4
Perry Babin is offline Perry Babin  United States
If the fuse opened, it opened for a reason. Generally, when they open, I find shorted power transformers. They will also open if the speaker wires short to ground or if the non-signal speaker wire contacts a 12v source.
The mouser part number is:
576-0468001.NR
Order extras.
To check for a shorted transformer, ground your scope to the chassis ground of the amp. Connect the secondary center tap of the power transformer to the chassis ground via a relatively high value resistor (1k-10k). Connect your scope probe to the center tap of the power transformer. With the amp on and ALL transistors clamped to the heatsink, twist, push, pull on the transformer. If the line on the scope ever moves from its reference point (0v, ground), the transformer is intermittently shorted.
Old 4th November 2008, 09:49 PM   #5
I don't have a scope yet , and I bought the amp on ebay so who knows what happened to it.
Is there anything else I should check before I order the fuses?
Old 4th November 2008, 09:59 PM   #6
You can use a 12v lamp in place of the scope. You can also use your voltmeter set to DC volts but neither of these will be quick enough to catch a really quick pulse.
Old 14th November 2008, 08:21 PM   #7
I replaced the fuse and checked the best I could for the transformer to be shorted.
I didn"t find any thing wrong with the transformer.
It is playing fine with no noise except when I adjust the gain it sounds scratchy.
Old 12th January 2009, 04:37 AM   #8
chipper is offline chipper  United States
Send a message via MSN to chipper Send a message via Yahoo to chipper
Theres other fuses on this amp? If so i had no idea because i'm currently having a bit of trouble my self with this amplifer. My problem is trying to find the right Resistance value for the Gain knob. It wont play with out all it just does is make a loud screech sound.
Feel the PUNCH
Old 12th January 2009, 11:05 PM   #9
the fuse is smd with the letters TH on it right by the rca's .
that is what was wrong with mine.
Old 18th January 2009, 11:05 PM   #10
I got it done already with the help of my electronics teacher at school. And i must say this amp is really inpressive and more power than i probably need for two ten inch Rockford Fosgate Punch XLC's. This site is very handy when need and the people are very helpful.
Feel the PUNCH
kicker DX700  problemsHide this!Advertise here!
Kicker DX700 trouble chipper Car Audio 5 14th January 2009 09:45 PM
I need help with a Kicker DX700 chipper Class D 5 8th January 2009 08:45 PM
Kicker DX700 Problem th3subtl3on3 Class D 2 14th April 2006 04:19 AM
Kicker DX700 classD; how can it drive a 1ohm load? SHOdown Class D 42 8th February 2005 01:22 AM
Copyright ©1999-2017 diyAudio
