soundstream van gogh 800.5 turns off...
Old 3rd November 2008, 10:11 AM   #11
fs1lag is offline fs1lag  Belgium
Send a message via MSN to fs1lag
well installed it in the car again yesterday, sounds as good as ever and this morning to work still all ok :-)
one problem though while connecting i noticed one of the channel (n4 or 3) does not produce a clear sound, there's a little cracking in it, like when the speaker is broken (which i first thought)
does anyone know what the cause may be for this issue?
Old 4th November 2008, 03:10 AM   #12
Perry Babin is offline Perry Babin  United States
Dirty contacts in switches or potentiometers can cause this. Have you tried moving all of them to see if it makes a difference?
Have you tried swapping RCA signals from other channels?
Have you tried swapping the speaker wires from a working channel?
If the problem is made worse when you tap on the amp, you probably have a broken solder joint in the defective channel.
Old 30th March 2009, 08:04 PM   #13
after a couple of months lying here i've got myself a new (other) car in which i needed it to work again, so open it went and i saw 1 little condensator 100F which had blown :-) when redoing all soldering in the past i accidently made a short circuit, i replaced the C and redid the soldering again of most things and now the amp is working again like it should for over a week now! :-)
Old 5th May 2009, 08:06 PM   #14
and for 2 months already now :-) so it's finally repaired like it should, again thanks for the thinking along :-)
soundstream van gogh 800.5 turns off...Hide this!Advertise here!
Precision Power PC6600.2 Amp turns on then immediately turns off. Need help! autolink Car Audio 4 15th March 2009 03:12 AM
Soundstream Van Gogh 1600.2 broken beatlessinOhio Solid State 1 19th June 2006 11:48 PM
Van Gogh Drivers?? Gelroos Full Range 1 22nd November 2005 02:59 AM
Which turns you on? nl Digital Source 0 30th July 2004 11:50 PM
Copyright ©1999-2017 diyAudio
