Help me fix MTX 152 and MTX 500D
Old 7th December 2008, 09:19 PM   #91
hakentt is offline hakentt  United States
I see you don't want to answer my question. I asume that you already answered my question and refuse to elaborate further.
That said, you should replace the 0.1 with the correct cap now that you know the correct value
Old 7th December 2008, 10:20 PM   #92
Perry Babin is offline Perry Babin  United States
I forgot to reply but...
If the 'wrong' cap isn't causing a problem because it's value is too low, why replace it with another cap that's the wrong value? Wait until you order parts and order the correct part. Then replace the 0.1uf.
Old 8th December 2008, 12:53 AM   #93
It is not about what correct parts fits that, I already know. But I want to learn about what does that capacitor do? Why is the value so high on that capacitor and why is the value lower on the same capacitor in different amps? Why not use another version of capacitor not mylar?
Old 8th December 2008, 01:39 AM   #94
As I mentioned before, the capacitors shunt (bypass) high frequency noise to ground.
The capacitor is placed at the terminals so that's it's most effective at shunting the noise and prevents it from getting into/out of the amp.
Aluminum electrolytics are not as good as ceramic or film capacitors because they have relatively high ESL (Equivalent Series Inductance) and the loss (inability to pass efficiently pass current) at higher frequencies is greater.
When low impedance at high frequencies is needed and the total capacitance needed is not significant, ceramic, film or tantalum capacitors are used.
The value used is up the the designer, in most cases. You can vary the capacitance significantly and make no audible difference. If the amp must pass certain tests for noise (on the power supply lines), the designer may have to increase the capacitance to meet spec. 0.1uf is a good starting point. If the amp is generating too much high frequency noise on the supply lines (across B+ and ground), the designer may increase the value.
Old 8th December 2008, 07:26 PM   #95
I got the 4.7uf50v capacitor film that you have to match the polarity, can I use this instead of Mylar type?
Help me fix MTX 152 and MTX 500DHide this!Advertise here!
mtx 500d problems ampjunkielikeme Car Audio 40 23rd February 2009 05:30 AM
MTX 500D help audiobahnkid592 Car Audio 28 15th July 2008 12:43 PM
memphis mc-500d @1 Ohm lincolntc Car Audio 15 6th April 2008 05:43 PM
Help me repair my MTX 500D please! hakentt Car Audio 28 5th February 2008 08:36 PM
Another dead MTX 500D dpaton Car Audio 1 22nd September 2007 08:53 PM
Copyright ©1999-2017 diyAudio
