Lighter adapter noise
Old 15th October 2008, 11:32 PM   #11
I Am An Idiot is offline I Am An Idiot  United States
Thanks for taking the time to let us know you now have it working. Hope it makes your daily commute more enjoyable.
If it ain't broke Don't fix it
Old 16th October 2008, 04:04 AM   #12
tsmith1315 is offline tsmith1315  United States
tsmith1315's Avatar
Because this is a directional isolator I had to buy two male/male and two female/female RCA plugs to make it work.
I'm curious as to how or why it's directional. Are they stepping up voltage, compensating for transformer loss, or what?
The GLI's we used to get were just 1:1 transformers, as ppia600 described.
Tim
Old 17th October 2008, 10:52 AM   #13
I know that they are marked input and output, I know that if you connect them backwards you WILL lose about half of your low frequency output.
Old 17th October 2008, 12:39 PM   #14
ppia600 is offline ppia600  United States
I think that is only for the ones that aren't 1:1. I remember some being sold that were purposely a different ratio for amp input impedance purposes, can't remember which brands.
Don't worry... you can always turn the gain down!
Old 17th October 2008, 05:48 PM   #15
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
I opened one before and one winding is wired directly to the plugs and the other winding is wired through a DC blocking cap before the plugs. can't remember which one is input and output.
Old 18th October 2008, 01:30 AM   #16
I opened one up today and just as DJ stated, there is a capacitor in series with the input winding. No capacitor on the output winding. One winding had a DC resistance of 125 ohms. The other read 100 ohms. I forgot to notice which was the higher reading the input or the output. So obviously the ratio is not 1:1, this may explain the reduction in sound that I have noticed. It may have seemed as a reduction in the low frequencies because it was probably on the sub amplifier. It was probably just lowering everything, just could not hear that on a sub setup.
Old 18th October 2008, 04:27 AM   #17
tsmith1315's Avatar
From dj's comment, I assume the caps are polarized?
After looking at the link supplied by RdJay, PAC quotes a 1.3dB voltage gain for the GLI. That's reasonable for the resistance you measured.
However, the directionality could be more a function of impedance than gain. Typically, the output impedance of a HU/processor is an order of magnitude less than the input impedance of a processor or amp. The combined LCR Z's of the reversed GLI may not be in a happy place for the input of some amps.
How about the two wires beside the RCA pigtail, what are they for?
Tim
Old 18th October 2008, 05:33 AM   #18
Some amplifiers have to see ground on the shield of their input cable in order to operate properly. The 2 brown wires ground the shield of the output cables of the device. 1 wire for each channel.
Old 18th October 2008, 01:45 PM   #19
/\ +1
Lighter adapter noiseHide this!Advertise here!
adapter? Burnedfingers Tubes / Valves 2 11th March 2008 07:33 AM
Adapter or Transformer jdlech Multi-Way 2 16th January 2008 03:40 AM
sot 23-5 to dip 8 adapter biovizier Parts 2 24th July 2005 12:37 PM
