Go Back   Home > Forums > General Interest > Car Audio
Old 10th October 2008, 01:33 AM   #1
Default Circut for Bridging Orion GX amps?
Is there a simple circut for bridging the Orion GX model amps using the RCA inputs?
Old 10th October 2008, 02:02 AM   #2
I have heard rumors of someone building one that actually fit inside of the housing of a 5 pin din plug. Maybe somebody here can draw you a diagram.
If it ain't broke Don't fix it
Old 10th October 2008, 03:50 AM   #3
If you use the DIN input, it can be as simple as the circuit below. There is an op-amp under the resistors. You have to zoom-in or view it actual size to see it. If you want to build something similar, I can post the schematic. If you must use the RCA inputs (without using the on-board power supply), the circuit become much more complex.
http://www.bcae1.com/temp/IMG_5951b.jpg
Old 10th October 2008, 04:11 AM   #4
tsmith1315's Avatar
(edited out the explanation as Perry covered it while I was typing)
An easier way is to buy this one:
http://cgi.ebay.com/ORION-400-BDG-BR...d=p3286.c0.m14
Geez, what a long link. If that doesn't work, item # is 200261612700
Be sure you can feed those GX's the current they're going to ask for.
Tim
Old 10th October 2008, 11:08 AM   #5
spooney is offline spooney  United States
i'd be interested in seeing that schematic perry as I have a gx series amp that i'd like to bring back to life.
Old 10th October 2008, 12:37 PM   #6
The following folder has a Flash file (.swf extension). You can zoom in to see the details better.
The photos are one I assembled for testing. I used 4.7k resistors in it. I used 10k In the Flash file. Either will work. There are no capacitors in the photos. They are probably not necessary but I'd suggest using them. If you're using Firefox, simply click the photos to zoom in/out.
The op-amp is a TL072.
http://www.bcae1.com/temp/dinbridgingmodule/
Let me know if you have any questions or find any mistakes.
Old 10th October 2008, 03:52 PM   #7
I guess it wasn't a rumor.
Old 10th October 2008, 11:14 PM   #8
Where do I get the DIN cables from? Are they standard RCA to DIN cables?
Old 10th October 2008, 11:20 PM   #9
For the DIN bridging module, you'll buy the DIN connector and use standard RCA cables (RCA connectors cut off of one end) to connect to the DIN module components.
Old 15th October 2008, 11:28 AM   #10
Thnks for all the help.
tsmith1315 - I will be using 4 gauge for each GX280 run mono.
Perry - I am not an EE, so I need a little more detail. Where would the caps go.? I have seen the TL072 range in price considerbly, from $1.32 on Parts Express to $11 each (inc. shipping from HK) for these on ebay;
AD8620 SMT Dual Opamp for OPA2604 TL072 NE5532 OPA2132
Does it matter? can your recommend a source?
Orion 2150SX Bridging? 2Ohm stable? cgull Car Audio 9 28th March 2007 12:46 PM
orion hcca 250 pop-top bridging leghi21 Car Audio 6 23rd January 2007 08:35 PM
bridging ucd amps mazurek Class D 13 6th June 2006 05:45 AM
Bridging many op amps Bazukaz Chip Amps 12 25th January 2006 07:47 PM
bridging amps? mikee12345 Multi-Way 4 24th March 2003 03:08 AM
Page generated in 0.09364 seconds (77.06% PHP - 22.94% MySQL) with 11 queries
