Old Lanzar amp problem - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 4th October 2008, 01:27 PM   #1
skooter is offline skooter  United States
Default Old Lanzar amp problem
I have a old lanzar vibe amp and it works and everyting just when you have volume turned up say to 15 on deck, when a bass note hits the amp cuts off and goes into protection mode unlill I turn it, off and back on, then it comes back till the next bass note. on low volume it dosent shut off. and this is with a 4 ohm load.
Old 4th October 2008, 05:54 PM   #2
If the woofer and the wiring are intact and the voltage to the amp isn't dropping significantly, the protection circuit in the amp may be too sensitive or damaged.
Old 10th January 2011, 01:57 AM   #3
Default lanzar safety feature trips and shuts amp off for no reason...
ok, I have the same problem with my lanzar amp... How could I fix this amp???
Old 10th January 2011, 07:54 AM   #4
Have you confirmed that no speakers are defective?
Have you confirmed, with a multimeter) that the voltage at the power and ground terminals of the amp are not dropping below ~11v?
Lanzar car dvd player amphead123 Digital Source 0 22nd February 2008 07:08 PM
lanzar 546-- problem with hissing noise over one channel jmg Car Audio 3 31st January 2008 04:00 PM
Lanzar Vibe 1800D Problem, please help! manni Car Audio 3 13th October 2006 10:20 PM
lanzar car stereo candlecutter Car Audio 4 10th January 2005 03:49 PM
Copyright 1999-2017 diyAudio
