Orion 275 XTR noise
Orion 275 XTR noise
Old 8th October 2008, 01:03 AM   #21
I Am An Idiot is offline I Am An Idiot  United States
If the RCA jack is the problem, it will be broken under the block. Using your meter, check for continuity between left in shield and left out shield, while gently pushing the block toward the inside of the amp. If you get nothing close to a dead short between the 2, one of the legs are broken at the circuit board.
If it ain't broke Don't fix it
Old 8th October 2008, 01:39 AM   #22
Perry Babin is offline Perry Babin  United States
If the two right channels are closest to the board, you'll probably have to repair the one you have (unless Orion can supply replacements).
Most of the replacements I've found are like the ones Rockford uses. The right channels are above/below each other. If yours are unrepairable, you may be able to disassemble the available jack to move the rings from one shield housing to another.
Orion 275 XTR noiseHide this!Advertise here!
Low noise transistor and noise figure Real_Macgyver Solid State 28 27th July 2012 09:42 AM
First Gen 225 Orion SS64 Car Audio 13 14th December 2008 11:54 PM
Orion 250 amp mike49504 Car Audio 11 21st November 2008 04:45 AM
Orion #5 Clipped Car Audio 1 21st November 2008 04:34 AM
Orion NT 200 vs Orion 2150 SX Clipped Car Audio 3 12th June 2007 01:55 PM
