Go Back   Home > Forums > General Interest > Car Audio
Old 20th September 2008, 04:26 AM   #1
skooter is offline skooter  United States
Default sub sounds
Getting everything dialed in today an got it jamming with some good rock (evenesence) think thats how you spell it, and got in the back with my sub box and the subs are making a popping noise. Not a cracking pop, kinda sounds like, if the sub cone was touching a cardboard box or something. tuned vol down a touch and all is good. Is this the point where the subs are at there limit of power, or is box too small or big. it is 98.9 sealed.
Old 20th September 2008, 04:46 AM   #2
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
Default Pop sound
From your description the cone is reaching its maximum excursion limit, the cone is striking something inside telling you it has exceded its limits. This 'limit' is noted in the drivers specification as Xmax..measured in Millimeters usually. Is your box internal volume the correct size or did you just put it in any ol' box? There is some math to do to get it working at its best.
___________________________________________Rick... ......
Old 20th September 2008, 04:52 AM   #3
Default Box is to size
I made the box a tad bigger than recomended. I have 2 12" in a 2.80 sealled box Running them with a PPI PCX2200
Old 20th September 2008, 05:09 AM   #4
A bit bigger box won't affect the excursion much...ever so slightly. The volume of your enclosure tells me your drivers are of the "Car" subwoofer types..The single 12" Dual coil sub in my photo required some eight or so cubic feet to run properly...on a single driver!
When I had it set up in the house, I had a rather large box made up using one inch MDF, braced, with two inch screws with glue every five inches. Weighed a ton, but boy could it go way down in frequency! would vibrate things across a table some ten feet away.
________________________________________Rick...... ...
Old 21st September 2008, 01:26 AM   #5
Your hitting the limit of the subs.
Old 21st September 2008, 03:47 AM   #6
When overextending a speaker, it does not sound as though cardboard is touching the cone.
If it ain't broke Don't fix it
Old 21st September 2008, 05:50 PM   #7
Jonny Hotnuts's Avatar
Separated spider?
Old 25th September 2008, 10:56 PM   #8
I ran into this same problem with a pair of Infinity kappa 12"s a few years back, It reached x-max and streched the surround past it's limit, and the surround tore away from the cone just the littlest bit we're talking less than an inch here, I didn't even notice untill I pulled the woofer from the cabinet and ran my finger around the surround from inside th basket. If your subs have dual spiders one of them could have seperated from the basket
l7 sounds bad. help please!! Kamakazi_pimp Subwoofers 0 3rd December 2007 06:53 AM
Sounds like you are there. davidlzimmer Music 26 9th May 2006 08:02 AM
WMA vs AAC#which one sounds better? sagarverma Music 0 21st January 2006 01:08 PM
zen or jlh which sounds better renjiish Solid State 33 9th October 2004 07:34 PM
gc sounds different (better) after a while .... matjans Chip Amps 41 30th January 2004 03:10 PM
Page generated in 0.09971 seconds (79.53% PHP - 20.47% MySQL) with 11 queries
