Go Back   Home > Forums > General Interest > Car Audio
Old 14th September 2008, 03:05 PM   #1
skooter is offline skooter  United States
Default Installing a 4" cooling fan
I am wanting to install a cooling fan for my amps and was wondering is there a was I can hook it up to where it comes on when the amp turns on?
Old 14th September 2008, 04:06 PM   #2
Connecting Additional Devices to the Remote Turn On Wire
Using a 30 amp SPDT relay, connect terminal #87 to constant 12 volts positive with a fuse rated to the sum of the additional accessories you've added and the components you need to turn on. (If you have two fans rated at 5 amps each and a neon light rated at 10 amps, you would use a 20 amp fuse plus 200 ma for each amplifier and processor.) Connect terminal #85 to ground, terminal #86 to the remote turn on wire from the head unit, and terminal #30 to each accessory with an appropriate fuse. A fuse (not shown) could also be used between the output of the relay (#30) and the remote turn on wire of the amplifiers and/or processors for extra precaution.
If it ain't broke Don't fix it
Old 14th September 2008, 06:05 PM   #3
jol50 is offline jol50  United States
I used to always run two amps and a PC case fan off the remote, but newer HU take less and less draw on the remote wire so good idea to run everything off a relay like that if you have more than a couple amps.
Old 14th September 2008, 07:33 PM   #4
Default Thanks...........
this is a 4" brushless fan. I am just running 1. I was told I could just hook into the remote wire on my Alpine 9805 and it would be fine. but fugured I would check. thanks
Old 14th September 2008, 08:52 PM   #5
grjr is offline grjr  United States
it is safer to use a relay, some of those fans can draw quite a bit of current and can burn out the remote turn on circuitry in the head unit
Old 14th September 2008, 11:24 PM   #6
Default thanks for the help
Thanks.
Old 15th September 2008, 01:02 AM   #7
PC case fans take pretty small amperage and often say right on them, and some HU actually tell what current you can run. IMHO new HU are piles that can't run stuff on the remote, but I have read some horror stories of newer HU blowing the remotes and does not sound like fun. I ran two sometimes three amps and a std case fan on an older alpine HU with no problem for years but like I said, I've been told its not a good idea on newer HU. Relays are cheap.
If you look hard, I once did find a page that told what amps took in current and explained this issue better.
Old 15th September 2008, 06:49 PM   #8
ppia600 is offline ppia600  United States
Like I am an idiot said, use a relay. Install it behind the deck so anything downstream of the deck will have plenty of voltage and current.
Don't worry... you can always turn the gain down!
Old 16th September 2008, 02:51 AM   #9
PPIA How was Ike? Gustav was serious here.
Old 16th September 2008, 02:55 AM   #10
Pretty bad flooding, luckily (sort of) I have a trailer. I hope to move further north into a decent home one of these days. Just got power back today. This is me taking a swim in the impreza, luckily no water got in, lol
http://www.youtube.com/watch?v=amgBGcanFxU
ETI480 - is "factory" cooling enough? peter12 Solid State 0 25th August 2005 12:15 PM
Installing a Box In my car osiris Car Audio 3 6th April 2005 12:06 AM
Installing a "main out" in an integrated amp? driving Solid State 0 11th December 2004 10:07 PM
Cooling an amp with poor cooling BAM Solid State 8 31st December 2001 04:40 AM
Page generated in 0.09039 seconds (81.62% PHP - 18.38% MySQL) with 11 queries
