Go Back   Home > Forums > General Interest > Car Audio
Old 29th August 2008, 10:23 PM   #1
skooter is offline skooter  United States
Default polk componets.
Hooking up 6.5 mid and sep tweeter to the crossover network they are 4 ohm each. dose the amp see this as a 4 ohm load or a 8 ohm load.
Old 29th August 2008, 10:32 PM   #2
Speakerholic
Cal Weldon's Avatar
If that are separated by the XO then the amp will still see 4 ohms. They're not really running in parallel in the sense they are each only covering their own part of the frequency spectrum. If they are not separated the amp will see a 2 ohm load if run in parallel. The only way to get 8 ohms is to run them in series which you simply wouldn't do.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
polk componets & Kicker 352xi amp Failure skooter Car Audio 9 4th September 2008 10:00 PM
Adding new componets in Protel bowdown Everything Else 0 19th May 2005 07:22 AM
Best X-Over Componets Mason Multi-Way 5 29th November 2001 12:32 AM
Page generated in 0.06058 seconds (67.19% PHP - 32.81% MySQL) with 10 queries
