Go Back   Home > Forums > General Interest > Car Audio
Old 25th August 2008, 10:41 PM   #1
Tom7227 is offline Tom7227  United States
Send a message via AIM to Tom7227
Default Clarion VRX935 info needed (LA4750)
Guys,
Does anybody perhaps have the schematic for this car radio?
I really only need a pin out for the LA4750 amp IC.
Probably this IC, and I have a feeling there is none avaiable.
TIA
Tom
Old 26th August 2008, 12:08 AM   #2
LA47501?
Old 26th August 2008, 02:19 AM   #3
No.. Just LA4750
Old 26th August 2008, 03:05 AM   #4
PacParts lists the following:
IC LOC# IC1015 (LA47501) POWER AMP
This is for the VRX935VD.
Old 26th August 2008, 03:21 AM   #5
Thanks perry..
Did you have the schematic for that unit?
Old 26th August 2008, 03:36 AM   #6
I couldn't find the schematic at any of the sites I use.
Old 7th February 2010, 11:20 PM   #7
i need a schematic for a vrx935vd please! i need a plastic gear that i broke trying to force the screen up and need the part number. thanks
Old 8th February 2010, 12:56 PM   #8
anyone?
Old 8th February 2010, 03:54 PM   #9
you might have a problem there. replacement gears are almost impossible to obtain unless you make them youself.
Old 8th February 2010, 04:55 PM   #10
The service manual is available from PacParts for $20. You'd have to buy the service manual, look up the part and then check with PacParts to see if it was available. Sometimes the individual gears are available, sometimes you have to replace a larger assembly to get the part. If this is like other similar Carion units, you'll have to buy the entire slide mechanism which is $59.
A-40 info needed tuberider Pass Labs 6 10th February 2009 05:55 AM
Info needed on 1 sub 1 amp skooter Car Audio 3 27th July 2008 01:25 AM
Missing Info - Help Needed ROVSING Parts 4 10th September 2007 10:00 AM
more info on d'apolito needed blu_line Multi-Way 4 17th October 2002 01:52 PM
LM3876 amp info needed jude ward Solid State 12 9th January 2002 07:08 AM
Page generated in 0.10909 seconds (78.25% PHP - 21.75% MySQL) with 10 queries
