Go Back   Home > Forums > General Interest > Car Audio
Old 25th August 2008, 04:48 AM   #1
npenson is offline npenson  United States
Default Ppi A600
I have a old a600 the black case, it seems to run hot and does not put out the same a one i owned about five years ago, I have been looking at the old posts and I cant find much stuff on the a600, alot on the a600.2 but the internals are not the same, I have been checking the transistors but I am not sure if this could be the problem or if my readings are correct, what should they be reading. (this setup is identical to my old one same speakers and everything just a different a600 but it seams to have half the power as my old one)
thanks
nick
Old 25th August 2008, 06:28 AM   #2
Are both channels working?
Does the amp run hot at idle (powered up, no RCAs plugged into the amp)?
Old 26th August 2008, 01:43 AM   #3
It doesnt run hot without the rca's plugged in but does get a little warm both channels do work, just seams underpowered. My old A600 would rock these 12's. And it runs alot hotter than the old one. One of the BDT81's and one BDT82's was getting a odd reading was not shorted just was giving different readings than the rest and was not sure if this was normal.
thanks
nick
ps
sorry about the double post new to the forum
Old 26th August 2008, 01:45 AM   #4
Speakerholic
Cal Weldon's Avatar
That's OK, I just deleted the other thread since there were no replies. Welcome to the forums.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 27th August 2008, 11:36 PM   #5
anyone else have any thoughts on this, ideas?
PPI A600 problems Riveted1 Car Audio 5 29th January 2009 09:35 PM
PPi A600 noise MHFidelity Car Audio 5 29th September 2008 07:13 AM
profile A600 2 ch jrod666999 Car Audio 9 18th March 2008 11:26 PM
Help with a damaged PPI A600.2 punchpeanut Car Audio 7 16th February 2004 06:30 PM
Page generated in 0.07718 seconds (69.04% PHP - 30.96% MySQL) with 10 queries
