Repair SMD in amp - diyAudio
Go Back   Home > Forums > General Interest > Car Audio
Old 22nd August 2008, 07:31 PM   #1
Default Repair SMD in amp
I am about to begin repairing an Xtant x603 amplifier and will need to replace some surface mount resistors.
HOW do you remove the old and re-solder the new ?
Thanks !
Old 22nd August 2008, 10:36 PM   #2
To remove the old resistors...
Apply new solder to both ends. Heat one end for ~2-3 seconds and then 'quickly' move the iron to the other side. If your iron is hot enough, the resistor will immediately slide off of the pads when the solder melts on the second pad.
To replace the resistor...
Remove the old solder from both pads with desoldering braid. Apply solder to one pad. Hold the new resistor with tweezers, hemostats or whatever you have handy. Heat the pad with the solder on it and slide the resistor into the molten solder. Reposition if necessary and then solder the other pad.
Old 23rd August 2008, 04:42 AM   #3
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Soldering SMD resistors and capacitors down to 0805 size (and other two or three lead devices) is quite easy if you can get the right type of tweezers and a soldering iron with a fine tip.
To unsolder components: Heat both ends alternatively and quickly until it comes loose.
To solder components: Hold the component in place with tweezers and solder one end. Then press with the tweezers on the center of the component to keep it in place while you heat both ends alternatively to make it seat properly on the PCB. There is no need for removing the solder that way.
I use to feel like the small child in The Emperor's New Clothes tale
Old 23rd August 2008, 07:12 AM   #4
In car amps, the resistors that fail often produce significant heat and the solder is badly oxidized. Using solder that's badly oxidized will produce a poor solder connection. If the resistor failed quickly and the solder is is not oxidized, you should use additional flux to float contaminants to the surface where they can't cause any problems.
DHD should repair? Solosound Car Audio 5 9th November 2008 08:39 PM
my amp repair benlebow Car Audio 3 10th February 2008 01:30 AM
Nad 304 repair big jim Solid State 0 30th December 2006 12:19 PM
CDM 9/44 to repair CDM 9 Pro Duson Digital Source 1 12th October 2005 05:41 PM
Help for repair my KSA 100 Alex helge Solid State 76 23rd October 2003 04:38 PM
Copyright ©1999-2017 diyAudio
