i am just wondering if anyone can recommend a place to try and purchase parts and pieces from. so far i have only heard of mouser.com.
or if i should be loyal to any specific manufacturer? like texas instruments or fairchild when i have a choice. where do you buy from and why? |
#2 |
digikey.com
mcminone.com componentsuperstore.com I prefer International Rectifier/Vishay for FETs. For BJTs, I prefer On-Semi. Never use NTE or similar parts. I've seen a very high rate of failure for Central Semiconductor parts.
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 | |
I have seen in a store that sells NTE parts. the semicons all appeared as if the original number was sanded off and an NTE number stamped on. |
#4 |
That's generally what they do. The problem with using the NTE parts is that you never really know what part you're installing. Many times, they'll have one part number to cover many other parts (all with slightly different specs).
With class D amps and switching power supplies, it's often important to use precisely the same part as the original. Very small changes in the electrical characteristics can make a huge difference. In some class D amps, transistors that have been changed VERY slightly by the manufacturer will not work properly, even though the parts have the same number and essentially the same specs. NTE may have been OK in the 70s and may still be OK for TV repair but they are not a reliable sub for many of the newer amplifiers.
#5 |
Some places I have bought a few things from are:
partsexpress.com tigerdirect.com newegg.com hope this helps |
#6 |
I've found some interesting things on eBay, some sellers were from the USA, some in Canada like you, and a few in China & Thailand.
Generally I get harder to get parts from Digi-Key, Mouser, Parts Express, and things like a few ICs and microcontrollers (PICs especially) from eBay for my low-quantity projects. There is a seller from Canada (DIPMICRO) with pretty neat proto boards. Also, I've gotten a few things cheap from Futurlec.com but the shipping is terribly slow! |
| NCD components | rootbeer | Class D | 4 | 15th March 2009 04:09 PM |
| where to buy components | dayking79 | Solid State | 4 | 6th February 2009 06:46 PM |
| What are these components? | Mrpong | Parts | 4 | 15th January 2006 09:33 AM |
| components | Swanic | Parts | 0 | 11th November 2004 09:00 AM |
| amp and components for a 911? | jbrinkely | Car Audio | 2 | 23rd September 2004 12:18 PM |
| Page generated in 0.07782 seconds (75.41% PHP - 24.59% MySQL) with 10 queries |
