Go Back   Home > Forums > General Interest > Car Audio
Old 7th August 2008, 07:55 PM   #1
Default audiobahn a2201t
I have 20v on the right channel , this is after replaceing the output and driver transistors. I checked all resistors on this side also.
Am I missing something?
Old 7th August 2008, 08:40 PM   #2
jol50 is offline jol50  United States
What kind of signal is the driver giving the outputs?
Old 7th August 2008, 08:41 PM   #3
do you mean the voltage going from the drivers to the output?
all three legs of the drivers have between 17 to 20 volts
Old 7th August 2008, 09:07 PM   #4
Is the amp in the photo the same as yours?
Old 7th August 2008, 09:32 PM   #5
similar not exact
the output is arranged alittle different
heres a pic
its not the best pic ,
Old 7th August 2008, 10:21 PM   #6
The driver (2sd600) and a pre-driver (2sa1023) were also defective. There was also an open 47 ohm resistor (next to R63E in the photos)
that was from repair notes from a 6601t on the dvd
I am beginning to think that is my problem
Old 8th August 2008, 01:16 AM   #7
Perry knows much more than I, but if I had that kind of power on the bases I would find where it is coming from to start with. It should be the same layout as the other side.
Old 8th August 2008, 06:19 AM   #8
If you have +20v on the speaker terminal (black meter probe on the secondary center tap of the power transformer and red probe on the 3rd leg of the output transistors of the defective channel), either the NPN transistor is leaking (electrically - not likely since it's new) or it's being driven on by another component. Measure the DC voltage from leg 1 to leg 3 of the NPN output transistor. What is the voltage from 1-3 (black probe on 3)?
What is the voltage from 1-3 on the PNP output (red probe on leg 3)?
Old 9th August 2008, 04:08 PM   #9
npn
1. - .508
2.- 1.845
pnp
1- .236
2- 039.6
Old 9th August 2008, 04:49 PM   #10
I don't understand the numbers . #1 would appear to be the voltage from 1-3. What is #2?
audiobahn amp help audiobahnkid592 Car Audio 9 6th December 2008 06:52 PM
audiobahn amp A1500HCT chuchu31642 Car Audio 40 16th April 2008 11:30 PM
Audiobahn sub skooter Car Audio 1 24th November 2007 04:21 AM
audiobahn spl on_chrome Subwoofers 1 23rd January 2006 05:35 PM
audiobahn amp sethro Car Audio 2 12th August 2005 08:22 PM
Page generated in 0.10380 seconds (77.16% PHP - 22.84% MySQL) with 11 queries
