Go Back   Home > Forums > General Interest > Car Audio
Old 7th August 2008, 11:31 AM   #1
amc32 is offline amc32  United States
Default SoundStream Class A 5.0 issues
I don't have schematics for this amp. I know the unit is a high current amp.The amp powers up no problem,I have DC (6volts) on one of the outputs,the other one plays fine.Idle current is about 1.5amps.
Here's the issue the power supply rails are reading +- 16volts.But there are 50volt caps also in place. Do the rail swing up in voltage as needed much like (Zed) Hifonics.Or is it something I'm missing.
Amp is rated at 12.5 watts x 2 @ 4 ohms,it does that with no problem.
It's the 250 watts x2 @ 1/2 ohm that I'm somewhat skeptical about.
6 volt dc out on speaker terminal.I believe driver board has taken a dump.Are they still available as a whole or would I be better off rebuilding it.Have concerns over what looks like a 8 or 10 pin IC used in it.May not be readily available.
Any comments on any issue would be appriciated.I'm tired of kicking it around and would like to get rid of it working properly than having to part with it broken.
Old 7th August 2008, 12:58 PM   #2
I have the schematic. Email me so I can send it to you.
babin_perry@yahoo.com
The driver boards are available but are also easy to repair. jandrelectronics on eBay has them.
http://stores.ebay.com/JandRelectron...QQftidZ2QQtZkm
If you decide to rebuild the driver board, let me know. There are a few things that make it easier.
Check for DC on the input of the driver board. If there is less than ~0.1v, the fault is very likely on the driver board.
In high power mode, the rails are supposed to be ±22. ±14.5 in high current mode.
Old 7th August 2008, 11:01 PM   #3
When you mentioned the rail voltages +- 22 and +-14 volts.
There are no switches on the power supply like the reference series.Are they auto switching from High Voltage from High Current?
Old 8th August 2008, 05:54 AM   #4
Yes. It switches automatically but it should start out in high power mode. The fault may be causing it to switch to high current mode.
Pwm Class D Issues packer Class D 21 24th February 2012 03:25 PM
Soundstream Class A 100 II - designed by Pass? Bronson_k Pass Labs 19 21st September 2010 10:52 AM
Soundstream Reference Class A 6.0 audiobahnkid592 Car Audio 0 9th January 2008 12:57 AM
problem with soundstream class 5.2 marko Car Audio 0 16th September 2006 09:43 PM
Page generated in 0.07627 seconds (70.88% PHP - 29.12% MySQL) with 10 queries
