Hey folks!
I'm in the process of installing a new Clarion DRZ 9255 in my Z3. When I plug the in the bus from the DC/DC converter the unit sounds like its got power, but the nothing happends when I try to turn the unit on. I used a meter to confirnm that I've got voltage. What else needs to be done? Pos/Neg/Remote are the only wires that I've connected. Positive and negative are straight from the battery. I'm driving myself crazy over this. Any help would be greatly appreciated. - Paul Herrmann |
#2 |
you mentioned positive and negative, did you also connect the ignition wire as well? this is usually a red wire that needs power only when the car is on or in the accessory position.
#3 |
The manual calls the red wire 12v acessory. I read this to mean that I would use it to power an acessory. So, you think I should connect the switched ignition wire to that?
Thanks much for your help! |
#4 |
You are brilliant! I looked at that 12V Acessory wire a dozen times and disregarded it while thinking "I don't have any acessories".
Thanks so much. This drama has been going on for weeks. - Paul |
#5 |
No problem! Glad i could help. i have been getting help here for a long time so i was due to chime in and help someone.
Enjoy your DRZ9255, i have heard that they sound nice! what speakers are you running? |
#6 |
I'm running all CDT. I've got 6.5 in front, 5.25 in the rear, and an 8" sub in a roadstersound enclosure between the seats. Zapco Ref. 650.6 for the front and a couple of Macs for the rear. Just having a few stumbling blocks along the way.
They DIY Audio forums have been a great help. |
#7 |
Dang 12v accessory wire had me tearing apart my wiring troubleshooting for hours. Thanks for the Solution sent all those years ago! lol
| Full-turn/partial-turn pots | slowpogo | Parts | 1 | 12th January 2007 07:40 AM |
| How can I reduce mechanical turn on and turn off noise? | soundNERD | Chip Amps | 8 | 28th October 2003 01:43 AM |
| Page generated in 0.08751 seconds (74.11% PHP - 25.89% MySQL) with 10 queries |
