JL 500/5 Part identification issue????
Old 20th July 2008, 07:37 PM   #1
Messerschmitt is offline Messerschmitt  United States
Default JL 500/5 Part identification issue????
Guys, seems that I'm always asking for your help and giving little of my own, but here's another stupid question. I have a JL Audio 500/5 amp that came to me with a 6 amp idle current draw. It was easy to find the shorted outputs (Q102 & Q104)on the front right channel, and I replaced them with a matching pair. The high current draw is now gone and the rest of the amp works as it should however the MosFets must have damaged their drivers as the Left front output is clipped and low powered. I have no schematic but the driver appears to be Q101. The part is marked K131 and C3198. Can anyone identify this part? Any additional advice on this amp would be greatly appreciated as I am new to repairing class D amps. Thanks, Messerschmitt
Old 20th July 2008, 09:25 PM   #2
Perry Babin is offline Perry Babin  United States
Q101 is probably the bias compensation transistor, not a driver. All of the drivers are on the vertical driver board.
The c3198 is a KTC3198.
http://www.keccorp.com/data/databook...ng/KTC3198.pdf
Are R140 and R141 within tolerance (±5%)?
Is the top, bottom or both clipped on the waveform?
Old 30th July 2008, 12:18 AM   #3
Default More about the 500/5
Well, this is just getting worse. I removed the KTC 3198 as mentioned in my last post. I brought it into my office to look for a cross reference and now it is gone. Probably in my wifes vaccuum cleaner. Does anyone know of a cross reference part or where I can get a replacement? I'll need to replace it before proceeding with my repair of the 500/5 and answer Perry's questions.
I have a water damaged 1000/1 that I could trade some parts from if needed.
Messerschmitt
Old 30th July 2008, 01:21 AM   #4
2sc3198
http://www.mcmelectronics.com/product/2SC3198
I don't think the 1000/1 has any in it.
Old 30th July 2008, 04:01 PM   #5
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
sorry for the slight off topic... just want to ask Perry something....
I'm having difficulty identifying a SOT89 SMD part... the markings are "BE" and then "RQ" below it. "BE" is identified as BCX55, there is no "RQ" in my database, but the BCX part is NPN and the part I need is PNP. any idea what it is or what is a good substitute?
it is part of a "half totempole" driver stage (the other half is the output transistor in the TL494) for the SMPS FETs (8pcs of 85N06).
Old 30th July 2008, 08:05 PM   #6
It's likely a 2sb1260.
Old 31st July 2008, 10:19 AM   #7
ok thanks!
Old 5th December 2008, 07:29 PM   #8
Solosound is offline Solosound  Mexico
Solosound's Avatar
Default JL AB driver board
¿What is the right part number for the green light diodes?
Thanks again!!
Old 9th December 2008, 10:41 PM   #9
Solosound's Avatar
Default Help please.
In the little AB board:
¿some one know about one good sustitute for the green light diodes?
Old 9th December 2008, 10:45 PM   #10
Are you sure it's defective?
JL 500/5 Part identification issue????Hide this!Advertise here!
Counterpoint SA-5000 P.S.U part identification needed Tubologic Tubes / Valves 3 25th April 2013 01:31 PM
Need help with TESLA part identification. TB Parts 7 11th January 2009 10:14 PM
Part Identification mjrpainless Car Audio 5 11th January 2009 01:00 AM
what part can take the place of ST part VB408B completely peterchen88 Parts 0 8th September 2007 05:45 AM
Copyright ©1999-2017 diyAudio
