Kenwood KAC-9102D Problems Kenwood KAC-9102D Problems - diyAudio
Old 11th July 2008, 04:29 AM   #1
Semms is offline Semms  United States
Default Kenwood KAC-9102D Problems
Hi, Iím new to the forum but have been reading the posts here for a few months.
Iíve repaired a few old school class AB amps in the past but this is my first class D amp. I bought this amp in non-working condition to try to repair for a project and Iím not sure where to start. As the title states it a kenwood KAC-9102D, it does not power up at all. I checked the power and output transistors on the board and they seem to be ok. I did a search on here and found this thread:
9102D thread
I took some power readings for Q3 and the tl4941 IC. I used a pc power supply for bench testing, it outputs 10.68 Volts at 10 amps(Iíve used this same power supply to test class AB amps that I have repaired). Here are the results I got:
TL4941 Ė pin1 .03, pin2 0, pin3 0, pin4 .03, pin5 .04, pin6 0, pin7 0, pin8 1.38, pin9 .325, pin10 .325, pin11 1.36, pin12 1.36, pin13 .64, pin14 .64, pin15 .64, pin16 0
Q3 Ė E=10.64, C=1.36, B=10.14
The few amps I have repaired have only had shorted transistors so Iím not sure where to go from here. The tools I have at my disposal are a DMM, an analog multi meter, and an oscilloscope. I understand the concepts behind how amps function and have built simple audio circuits before but Iím really kind of a newbie at this so any help would be greatly appreciated.
Old 11th July 2008, 07:59 AM   #2
Perry Babin is offline Perry Babin  United States
If the voltage from collector to emitter of Q2 is less than 1v, Q3 is defective. If you short from the collector to the emitter of Q3, the amp should power up. This will allow further testing.
If you short between those pins on Q3, have the transistors clamped to the heatsink and have a 10 amp fuse in the B+ line.
Old 11th July 2008, 03:13 PM   #3
Thanks, I'll try that after work and let you know what i find.
Old 11th July 2008, 04:24 PM   #4
just to clarify, do you mean put the positive probe on Q2 collector and negative probe on Q2 emitter and read the voltage or read the voltage from the collector referenced from ground and then from the emitter refrenced from ground and subtract?
Old 11th July 2008, 04:33 PM   #5
In theory, they should produce the same voltage (assuming that there were no open ground traces). In most cases, the difference will be insignificant. Here, it's easier to simply place both probes on the transistor and measure directly.
Old 12th July 2008, 06:07 PM   #6
The voltage from collector to emmiter of Q2 was 7.12V.
Old 12th July 2008, 06:21 PM   #7
7v is too much.
Do you have ~0.6v from base to emitter on Q2?
Does D4 have ~6.8v across it?
What is the voltage on the remote terminal of the amp?
Old 12th July 2008, 11:11 PM   #8
jol50 is offline jol50  United States
I had one that Q3 was bad, B & C had 1.7v powered up and 1.3 no remote and E was always B+ supply. Another one I had blew the ground trace on the board and thus took power away from the input section, but still had power to PS, it was hard to see so check the ground areas on the board. I think the case grounded and did it but not sure so look at case ground to board on bottom cover screw, mine was melted a little.
Old 15th July 2008, 01:42 AM   #9
I had .55 Volts from emitter to base on Q2, 6.72 volts across D4, and 10.68 Volts on the remote terminal.
Upon closer inspection while looking for D4 i noticed a blown trace(see picture). I've since repaired the trace but haven't tried to power it up yet. I'm wondering what might have blown the trace in the first place and is it a good idea to try to power it up or should i be looking for something specific. Thanks for all your help so far!
Old 15th July 2008, 01:42 AM   #10
the repair:
Kenwood KAC-9102D ProblemsHide this!Advertise here!
Kenwood KRF-V5560 memory retention problems capslock Solid State 0 16th May 2007 08:46 AM
Kenwood KAC 846 Problems cancruiser Car Audio 3 21st April 2007 06:20 AM
kenwood C2 + M2A apolon34 Solid State 8 22nd February 2007 03:18 PM
kenwood 9102d mike49504 Car Audio 13 18th October 2006 01:14 PM
Problems with my Kenwood KDC-MP925 saru Car Audio 4 16th August 2004 10:25 PM
Copyright ©1999-2017 diyAudio
