Go Back   Home > Forums > General Interest > Car Audio
Old 10th July 2008, 12:07 AM   #1
Send a message via Yahoo to scampo77
Default help indetifing components
how do i tell the difference between a output transistor and a power supply transistor? i am working on a smal MTX amp i have 4 small ones on one side of the amp and 2 large ones on the other side. the 4 on the one side are burnt and look failed. where do i buy them from?
the amp is MTX rtp251d and the numbers on the faild transistor are 18sf2f and 75339p
Old 10th July 2008, 12:24 AM   #2
One terminal of each of the output transistors will be connected to one of the speaker terminals.
One terminal of each of the power supply transistors will be connected to the power transformer.
The HUF75339P is used in the power supply. Mouser.com has them.
512-HUF75339P3
Old 10th July 2008, 04:37 AM   #3
i have 4 of these should i replace all 4 of them? one is a complete meltdown and one has no continuity between the outer legs
Old 10th July 2008, 07:36 AM   #4
There should be no continuity between the first leg and either of the other legs.
You should replace all 4.
Old 10th July 2008, 04:00 PM   #5
jol50 is offline jol50  United States
Go to Perry's site and it shows a basic layout for most amps. Usually 12v comes in through fuses and 16v (or higher) cap(s) and to PS transistors*, they hook to round torrid transformer, then to rectifiers* (usually two), then to large rail caps, then to outputs*, outputs through large resistors in front of them to speakers. Usually PS transistors have torrid close by, and outputs have all the small input circuits next to them. A few amps twist it around, but most are PS/output/input from one end to other. If not then usually that in a circle. Sometimes rectifiers are across from PS transistors (smaller amps), sometimes next to them on both sides (large long amps). Can also look at the numbers on the board to ID them as transistor or diode.
* = on heatsink.
Old 11th July 2008, 12:47 AM   #6
here is a picture of them. what is that thing in the middle of the 4? does it need to be replaced alongside the resistors? should i look for anything else? or just change these 4 and go try it?
of the 4 there are 3 different manufacturers? is this important?
Old 11th July 2008, 01:07 AM   #7
The two on the left are the rectifiers. They're probably not defective and won't need to be replaced.
If there are only two of the 75339s in the amp, you only need to replace those two. Are there 2 more 75339s on the other side of the amp?
The device under the foam is a thermistor. It's unlikely to be defective.
Old 11th July 2008, 02:03 AM   #8
well there are 2 additional transistors on the opposite side but they are much larger. they are both the same and they have the number "IRFP240" on them
Old 11th July 2008, 02:16 AM   #9
Those are the audio output transistors. What model amp is this?
Old 11th July 2008, 02:31 AM   #10
MTX rtp251d
NCD components rootbeer Class D 4 15th March 2009 04:09 PM
where to buy components dayking79 Solid State 4 6th February 2009 06:46 PM
What are these components? Mrpong Parts 4 15th January 2006 09:33 AM
components Swanic Parts 0 11th November 2004 09:00 AM
amp and components for a 911? jbrinkely Car Audio 2 23rd September 2004 12:18 PM
Page generated in 0.10434 seconds (77.98% PHP - 22.02% MySQL) with 11 queries
