Go Back   Home > Forums > General Interest > Car Audio
Old 4th July 2008, 04:58 PM   #1
marko is offline marko  United Kingdom
Default zapco psu wiring info (rj45)
does anyone have any info on the pin configs for zapco psu outputs? are they straight wired or crossover or other? gonna make my own cables so i can power a pair of SL30L's but need info!
also any info on running the signal balanced or unbalanced would be great
Old 4th July 2008, 10:42 PM   #2
I have no idea what cable configuration they use, nor do I have any idea on the balanced or unbalanced inputs. The only thing I can help you with is trying to figure out the pinout for op amp + and -. Since it has an rj45 I can only assume that it is a signal processor of some sort. If it is a processor and you can tell us what op amps it is using, we can start by getting the unit powered up. Then we can try to figure out the audio connections.
If it ain't broke Don't fix it
Old 4th July 2008, 10:48 PM   #3
the rj45 is for power, it uses mini din for signal like old pf eq230 has, just don't know pin configs of either and zapco are tight with info!
Old 4th July 2008, 11:08 PM   #4
Can you open the processor and get the part number of an op amp in the unit? Can you power the amp up and check voltages on the jack of the amp? I am assuming that it will have a + 15 to 18. A - 15 to 18 volts. And of course a ground connection. What are the power requirements of the processor?
Old 7th July 2008, 04:59 PM   #5
They are opposite on each end. So just flip the wires on one end
Old 7th July 2008, 05:42 PM   #6
thanks tristan, so if i were to loop the cable round without twisting it the colors would match? i wanna make sure i've got this bit right before i make them, don't want to blow any of my kit up
Old 8th July 2008, 08:39 PM   #7
Just to avoid any chance of messing up part of your kit, I would turn the amp on and find the + and - 15 or 18 volts, then I would take the cover off of the processor, locate the op amps, download a datasheet for said op amps, figure out which pins on the plug feed the plus and minus voltage to the appropriate pins of the op amp. Make your cable accordingly. This way there will be no chance of confusion.
Old 8th July 2008, 10:12 PM   #8
Are you speaking of the older Zapco PSI for the PX ?
Old 9th July 2008, 06:07 AM   #9
it's the psi-hpsl to driver processors, in my case a pair of eq30l's. they are phone style connectors for power...
Old 10th July 2008, 07:51 PM   #10
Its like this
Example (not actual wiring code)
one one end
red green blue orange yellow
on the opposite end
yellow orange blue green red
Just invert the wires
I2S and RJ45 socket excelon Digital Source 3 29th July 2008 09:18 PM
Volvo SC811 -> alpine CHM wiring info MadMutt Car Audio 11 4th February 2008 09:59 AM
Off Topic - 24 port RJ45 DS-1 patch panels mpmarino Swap Meet 0 7th November 2005 02:41 AM
Need wiring color chart info ? Keypad2k2 Car Audio 3 15th September 2005 09:18 PM
line array wiring info. J.k.Wilson Multi-Way 3 26th August 2005 04:15 AM
Page generated in 0.08667 seconds (78.57% PHP - 21.43% MySQL) with 10 queries
