Help to repair JL audio 300/2
Old 9th July 2008, 08:42 PM   #11
Solosound is offline Solosound  Mexico
Solosound's Avatar
Just for be sure...
Some one has the right values for Q510 and Q500?
Old 9th July 2008, 09:50 PM   #12
Perry Babin is offline Perry Babin  United States
I don't have information for the 300/2 but in the 300/4, Q500 is one of the power supply FETs. The power supply FETs in most of this series of amps is an IRFZ44.
In the 300/4 Q510 is an IRFZ34. If your amp uses the 3843B to drive Q510, it's likely an IRFZ34. An IRFZ44 would also work in that location.
If you have a scope, monitor the voltage on pin 20 of the audio driver board (looking at component side of driver board, it's the last pin on the right). If it's not very near 0v on one channel or you see a short pulse on one channel, you need to determine why it's going high.
Old 9th July 2008, 11:14 PM   #13
Solosound's Avatar
On this amp, all the power supply fets are FQP65N06, too Q510 are FQP65N06.
Always in all slash I have see the IRFZ44, this is the reason for my question.
300/2 PCB 100009
REV 1 9/22/00
Old 16th July 2008, 01:54 AM   #14
Solosound's Avatar
After few days, I will follow:
The intermittent shut down is finish. They shut down only if the volume is high.
The amp works, clean audio, but the current is 4.5 Amp.
The pin 20 itís OK. Thanks Perry
R513 and Q510 are very hot (I quit for measure, and they are ok.)
Old 16th July 2008, 02:44 AM   #15
Did you try adjusting the bias to reduce the current draw?
How is R513 being used?
There are probably several 4.7 ohm resistors near the filter capacitors for the small yellow transformer. Are any of them getting hot?
Old 17th July 2008, 12:49 AM   #16
Solosound's Avatar
the 4 resistors (4R7) are good and none hot when working.
R513 is 33 ohm, and itīs fine too.
Old 17th July 2008, 01:00 AM   #17
Is the diode in parallel with the 33 ohm resistor OK? You'll have to pull one end to check it.
Does the yellow transformer look like it's overheated (windings showing through the yellow tape)?
Do the waveforms look similar to these?
http://www.bcae1.com/temp/jl500slash...ransformer.swf
Old 17th July 2008, 05:28 AM   #18
Solosound's Avatar
The diode in parallel itís fine. Another near diodes is fine too.
The transformer not show visible overheat
When disconnect remote, The amp still turn on 5 seconds more.
In the same order:
Scope is setting to 5us, 5V.
Pin1
Pin2
Pin3
Pin4
Pin5
Pin6
Pin7
Pin8
Pin9
Pin10
Old 17th July 2008, 06:30 AM   #19
Is the vertical amplifier set to 5v/div for all waveforms?
If the vertical amplifier setting for pins 1 and 10 is the same, it appears that the transformer may be defective. Pin 10 should have DC (approximately the same as the B+ input).
Old 22nd September 2008, 04:28 AM   #20
Solosound's Avatar
After few months, I can bought one working condition yellow transformer.
Now the amp never shout down, but is current 4 Amp!!!!
Q510 is too hot, its a FQP65N6.
ŅAny idea?
Help to repair JL audio 300/2Hide this!Advertise here!
Cambridge Audio A5 repair job pulseezar Solid State 36 6th May 2012 03:06 PM
jl audio 300/4 repair brianfulcher15 Car Audio 3 16th June 2009 06:45 AM
lightning audio amp repair doughboi916 Car Audio 14 31st August 2007 10:05 PM
Atlas Audio Repair Helen Parts 2 31st August 2007 04:41 AM
Copyright ©1999-2017 diyAudio
