Go Back   Home > Forums > General Interest > Car Audio
Old 26th June 2008, 02:00 PM   #1
Default Stuff i got for free
I was helping someone out and for payment i recieved a good bit of car audio, and i would like to know the quality of it all. I got two 15" Rockford Fosgate subs. I cant figure out what ones they are online or on the site. They look just like the RFD2215 but instead of saying Punch on them they say Power. Also i recieved a Hifonics Zues Amp. And i believe a 60 watt capacitor. I dont really know anything about car audio and would like to find out if they are worth my time getting it all set up in my car.
piece of tin, piece of board, put it together you got a Ford
Old 26th June 2008, 03:18 PM   #2
tsmith1315's Avatar
The Zeuss should have a roman numeral following the name (VII, XX, etc?) There have been numerous changes to the line over the last 25+ years.
Someone here is bound to know the details on the subs.
What you have there is either pretty good, or very very good equipment depending on exactly what models the pieces are.
Regardless, it's certainly worth installing if you have room. And if you'd like advice on how to proceed, this is THE place to be!
Tim
Old 27th June 2008, 01:55 AM   #3
The Amp just says Hifonics at the top, Zues below it, and than at the bottom, it says Z4400 4 x 110 watts
Old 28th June 2008, 04:31 PM   #4
Clipped is offline Clipped  Thailand
Send a message via MSN to Clipped
Default Re: Stuff i got for free
i think your sub is an RFP with a 4" coil, the 'P'ower series is a step up from the RFD 'punch series with a higher ''Y" value for the magnet and a bigger voice coil...if you have a chance get it re-spidered with a thicker spider, then add about 1oz of weight under the dustcap...the original spider was too thin to support the weight of the 4" coil when mounted vertically.
but if it still works dont worry about it...but if you can spare $100 get the spiders.
the amp, if the specs you gave are correct, should put out around 500 x 2 when bridged into 2 channels...hook it up to an ammeter at idle and make sure it doesnt draw more than 5 amps at idle....measure the outputs at idle and see if it is putting out any DC...and come back
the RFP subwoofer was dual 2 ohm coils, so youd have to hook the coils up in series per woofer... then bridge it to the amp.
and the same for the other sub with the other set of bridged outputs of the amp.
if someone hooked the subs coils up in parralel per sub, theres a good chance the amp could be defective.
is it worth hooking up? your damn right it is...BUT you may want to check and see if the cap is still good though.
make sure you have atleast 2.5cuft sealed per sub, or 3.25cuft ported per sub...if you dont have the space dont waste your time.
3 cuft sealed and 4 cuft ported, should be the least...for acceptable performance.
Old 24th December 2009, 01:13 AM   #5
chipper is offline chipper  United States
Send a message via MSN to chipper Send a message via Yahoo to chipper
Punch Power DVC?
Feel the PUNCH
Old 24th December 2009, 01:40 AM   #6
ZippyTs is offline ZippyTs  United States
ZippyTs's Avatar
way to raise the dead chipper
Old 24th December 2009, 03:57 AM   #7
Well i was just browsing through some of these threads trying to wast some time and decided to put my $.02 into this even thought its a year later
Feel the PUNCH
Old 24th December 2009, 04:35 AM   #8
ZippyTs's Avatar
You did it might well at that too
Old 24th December 2009, 08:28 AM   #9
godfrey is offline godfrey  South Africa
Dead threads can feel mighty lonesome this time of year.
Doesn't hurt to pop in and say hello - just to show we still care!
Free Stuff! imix500 Swap Meet 7 18th May 2008 04:16 PM
spring cleaning FREE STUFF just pay shipping plus wtb/wtt ibook stuff relientk4life06 Swap Meet 3 24th May 2006 03:32 AM
free stuff mpmarino Parts 3 30th May 2005 12:34 PM
Free stuff! contaxchen Swap Meet 2 5th October 2004 03:38 AM
Page generated in 0.11253 seconds (82.52% PHP - 17.48% MySQL) with 10 queries
