Go Back   Home > Forums > General Interest > Car Audio
Old 14th August 2008, 02:59 AM   #11
spooney is offline spooney  United States
i'll give that a shot . it made quite a stink when i hooked it up backwards although there was never any magic smoke.
Old 14th August 2008, 03:05 AM   #12
That was probably the reverse protection diode (connected across B+ and ground).
Old 16th August 2008, 02:07 AM   #13
i pulled the power supply transistors and they appear to be in working order.I also pulled a couple other small transitors near the remote turn on input but found nothing unusual
Old 16th August 2008, 02:12 AM   #14
When testing the transistors on ohms, you should have only read something other than OL when you had the red probe on the base and the black probe on the collector and emitter. Did you read anything other than OL with any other connections?
Old 16th August 2008, 03:52 AM   #15
no i didn't. the only time i got any reading was with the red lead on the base and the black lead on either the collector or the emitter.
Old 16th August 2008, 04:12 AM   #16
They would appear to be OK.
Does the TO-220 case transistor standing in the power supply feed the small wires on the transformer?
If so, check it. If it's OK, is the voltage from leg 1 to leg 3 more than 0.3v with no remote voltage?
Old 16th August 2008, 05:25 AM   #17
I stumbled upon the problem just a few minutes ago.I was pulling the rest of the small transistors in the power supply when I found a leaky 2n3904 transistor.I threw in an mpsa06 in its place just for a test run and it luckily worked.the amp now only powered up with remote turn on applied.Is the mpsa 06 suitable to use in this application or should i just get the 2n3904?I have plenty of the mpsa06's on hand I just don't have any 2n3904's so if the 06's will work I can get the amp up and running much faster
Old 16th August 2008, 05:33 AM   #18
The A06 is a good sub. There's no need to replace it with a 3904.
old coustic 360 amp fongman Car Audio 41 22nd December 2009 01:38 AM
On-off LED turns off when I turn the Power on! gychang Class D 4 6th July 2009 12:49 PM
Precision Power PC6600.2 Amp turns on then immediately turns off. Need help! autolink Car Audio 4 15th March 2009 02:12 AM
Coustic Power Logic AMP160 Questions spooney Car Audio 6 15th January 2008 12:46 AM
Old School favorites go bad while I'm out of school...HELP! HayaBuddha Car Audio 5 26th March 2007 05:20 AM
Page generated in 0.09087 seconds (77.54% PHP - 22.46% MySQL) with 10 queries
