shorted out deck???
shorted out deck???
Old 18th June 2008, 10:36 AM   #1
new one is offline new one  United States
Unhappy shorted out deck???
Did something REALLY dumb.
Have a newer Pioneer deck which took out of car. Realized I left a CD in, and decided to eject. Was rewiring the harness for a different stereo, so instead of hooking up thru the harness, I jumped the yellew power & black ground wires directly to battery (yeah I know... dumb).
Sparked at battery terminal & blew 10Amp fuse in deck. When replaced fuse and then correctly rewired thru harness, the deck will not come on.
Any way to salvage the recever, or is it just a very small boat anchor?
Old 18th June 2008, 03:50 PM   #2
mike49504 is offline mike49504  United States
sounds like u either blew a diode or burnt a trace on the board only way to find out is take the unit apart and check the diode and look for any burnt traces
Old 18th June 2008, 11:31 PM   #3
Took unit down to circuit board. Could not find any burned traces or failed spots on the board. How can one tell if a diode is out? Any other ideas.
Hate to loose the unit over this... kind iof an expensive lesson if have to.
Old 19th June 2008, 12:34 AM   #4
Perry Babin is offline Perry Babin  United States
What model deck is it?
Old 19th June 2008, 12:58 PM   #5
well it still could be a couple of different things. Do u own a multi meter and if so check the diode behind where the harness plugs into the deck or u could have shorted out the main chip that controls powwer to the unit and speaker leads out if thats the case it still should only cost u around 20.00 to 25.00 dollars to buy the chip
Old 20th June 2008, 04:04 PM   #6
Dan2 is offline Dan2  South Africa
are you sure the wiring harness works?
Old 22nd June 2008, 02:09 PM   #7
I Am An Idiot is offline I Am An Idiot  United States
Since you just took it out of the vehicle, I would have to assume that the harness works. Since you said it blew the 10 amp fuse when connecting it to the battery, you said nothing about this, but I would have to assume that you connected it backwards. There is a diode in the unit that protects the unit in case of an event as this. You replaced the fuse and said nothing about it blowing again, if it hasn't blown again, I would have to assume that the diode is not shorted. If you saw no smoke when connecting it to the battery, I would have to assume that there is not a burnt trace, when opening a trace of this magnitude, you will definitely see smoke, not a little, but enough to say to yourself, hey I should mention that when posting this problem on the forum. When you connected it to the harness and it did not come on, did you use a meter to verify that you had voltage on the red and yellow wire of the radio? You never said anything about the red wire when connecting to the battery, some Pioneer decks require the switched wire to be hot in order to eject a disk.
You asked how can you tell if the diode is out. If it was connected backwards, the diode would fail by shorting. If the unit was properly fused, it would have not shorted. If it had shorted, it would blow the fuse again when you connected it to a power source. If it is not blowing fuses, it is OK.
If it ain't broke Don't fix it
shorted out deck???Hide this!Advertise here!
X-5 shorted center channel ROLIKOV Pass Labs 2 31st October 2008 07:39 PM
Pearl shorted...please help me out of this! h_a Pass Labs 28 4th June 2007 03:55 PM
How to determine a tube is shorted? Bing Yang Tubes / Valves 8 28th April 2007 06:03 PM
shorted turns in primary? mrshow4u Solid State 15 12th September 2006 06:09 PM
Help with Shorted Xformer lgreen Parts 1 27th June 2004 05:58 PM
Copyright ©1999-2017 diyAudio
