Go Back   Home > Forums > General Interest > Car Audio
Old 21st June 2008, 01:42 AM   #11
It may not be difficult to repair. The symptoms sound like power supply problems. These amps have problems with the busbars. The connections break and cause various problems.
If you can power it up and are willing to check voltage on various points, I'll tell you what to check.
Old 21st June 2008, 01:49 AM   #12
mandude is offline mandude  United States
Unfortunately I do not have a 12 power supply just lying around, and it would be difficult to use my car's power supply.
What is a busbar? Is that anything that I can check through visual inspection, or with a DMM without the amp powered up?
Old 21st June 2008, 03:59 AM   #13
The busbars are the metal jumpers. It's not likely that you'll be able to see any of the bad connections. It would also be difficult to find them with a meter.
You'd need to power up the amp and check voltage at several points. When you found that voltage was absent at a point where you should have voltage, you'd trace the problem back until you found the break.
If you don't have the ability to work on it easily, it's probably best that you pay to have it repaired.
If you don't know of a good repair shop in your area, call the local car audio shops to see who they use for repairs. If several shops recommend the same repair shop, they probably do good work.
Old 26th June 2008, 08:48 PM   #14
SS64 is offline SS64  United States
All Electronics Repair
2615 W. Glendale Ave. 85051
602 352 0362
Talk to Nick
he knows his sh** just don't make him mad.
It isn't fun unless it can kill you!
Old 27th June 2008, 04:37 AM   #15
Awesome, thanks, I will check that out!
I have also heard that Soudwerks in Scottsdale might be OK.
Moscow diy shops secanbj Parts 0 28th June 2005 09:52 AM
shops! radu19880625 Multi-Way 2 29th May 2005 06:12 PM
Metal shops in NY imix500 Parts 2 10th May 2004 06:10 AM
On Line shops gchrist Parts 0 9th April 2003 02:08 PM
Page generated in 0.07689 seconds (76.85% PHP - 23.15% MySQL) with 11 queries
