Has anyone here ever made their own level converter if so, how did it compare to a regular sni-35?
http://www.caraudioconnoisseur.com/ |
#2 |
I did quite a bit of manual adapting from speaker-level outputs, and from factory line outputs.
For speaker outputs, often an L-pad works fine. R values chosen to present a reasonable load to the HU & amp. Sometimes they require decoupling. What exactly is an sni-35?
Tim |
#3 |
It's a standard line level converter used in car audio installs. The problem is that the sound quality is only so so even for a line level converter.
http://www.sonicelectronix.com/item_...AC+SNI-35.html There are better ones but for the price I would rather build one of higher quality.
#4 |
I usually stay away from LOC's. if I need one, I make a basic stereo balanced line receiver with low enough gain and power it off the ACC line. works very well. the sound quality is limited by the parts you use and the HU itself.
#5 |
could you post some pics and or a schematic of how you make one? How does the piece you make compare to using a LOC SQ wise. The only reason I am not going to aftermarket is because I have a 6 disk cd changer in dash and love it. I don't want to change it until I am ready to put in a carputer.
If I could find someone to mod my head unit to add RCA's to it I would but I don't have the skill to do that myself.
#6 | |
Does your factory unit use an external amp?
Tim |
| Convert Line Level to Electric Guitar Level | miallen | Solid State | 4 | 16th May 2010 01:22 PM |
| speaker level input vs line level question | crippledchicken | Subwoofers | 4 | 17th July 2007 03:36 AM |
| lesser of two evils, high level -> line level, digital volume control | mazurek | Solid State | 3 | 19th November 2006 12:25 AM |
| diy speaker to line level converter | zobsky | Parts | 1 | 24th September 2006 05:31 AM |
| line level converter | b<ben>n | Chip Amps | 1 | 2nd March 2004 02:03 PM |
| Page generated in 0.09408 seconds (71.47% PHP - 28.53% MySQL) with 10 queries |
