Phono Leads, Wht have plugs on both ends?
In that case you can just run the front pre-outs to your mid/tweet amp, and the rear pre-outs to your sub amp, using the amps for x/o...
Did you look into your head unit having it's own x/o?
I'd imagine this would give you a better sound - reason being when I used my amps x/o, it distorted earlier than if I fed it with a seperate x/o..
Make sure you try your system without the rear speakers - you may be surprised......
Rob
Connecting the red/white RCA (phono) cables to a speaker level output can damage the amp (not likely), and more likely create noise. Avoid this if at all possible. A speaker to line level converter (about 10-15 bucks) can help, but if possible connect to the preamp outs.
