In that case you can just run the front pre-outs to your mid/tweet amp, and the rear pre-outs to your sub amp, using the amps for x/o...
Did you look into your head unit having it's own x/o?
I'd imagine this would give you a better sound - reason being when I used my amps x/o, it distorted earlier than if I fed it with a seperate x/o..
Make sure you try your system without the rear speakers - you may be surprised......
Rob
Rob
