Hi All, I am still kind of new at the forum and appreciate all the help. I just started working on a JL Audio 250/1. It powers up fine current draw looks ok. Power light is on low ohm and thermal are out. Amp has about a 65khz sinewave on the output with no input. I think it might be something with the low filter but don't know how to check it.
Thanks in advance for all the help. RJcrafts |
#2 |
What's the amplitude of the 65kHz signal with and without a speaker connected to the amp?
Does the current draw increase when you connect a speaker? How much DC voltage do you have across the positive and negative speaker terminals (black meter probe on the negative speaker terminal, red meter probe on the positive speaker terminal)? How much DC do you have from the chassis ground terminal to the positive speaker terminal (black meter probe on the chassis ground terminal, red meter probe on the positive speaker terminal)? How much DC do you have from the chassis ground terminal to the negative speaker terminal (black meter probe on the chassis ground terminal, red meter probe on the negative speaker terminal)?
Links >> Basic Car Audio Amp Repair --- Basic Car Audio Electronics --- Basic Transistor Testing --- Basic Switching Power Supply Design --- Basic Computer Skills << Links |
#3 |
Hi Perry, Thanks for the response. Here is what I have found,
1v p-p w load 0v p-p w/o load current draw about same w and w/o load 0v across speaker output terminals gnd to pos = 30.0 vdc gnd to neg = 30.0 vdc nice clean sine wave. I have looked closely all over the amp for and obvious component damage and ohmed out outputs, nothing appears shorted. Any ideas on where to start troubleshooting this amp would be greatly appreciated. Thanks RJcrafts |
#4 |
I'm not sure that there is a problem. Although I would have expected the with/without load numbers to be reversed, everything looks OK. The signal won't be audible. Many class D amps have similar leakage through their output filters and it causes no problem. If the amp produces clean output when driving a speaker, it's probably in good working order.
| TV Horz. Output Tubes used as Output Audio | ppl | Tubes / Valves | 90 | 27th August 2009 02:21 PM |
| Cambridge Audio 640C No audio output PLEASE HELP! | Kajman | Digital Source | 3 | 10th December 2007 09:45 AM |
| Audio output stage for cd (opa 627) | sopapo | Digital Source | 0 | 28th August 2006 03:12 PM |
| Marantz CD-7 audio output mod. | D.A.R.R.Y.L. | Digital Source | 23 | 5th June 2006 08:23 AM |
| Page generated in 0.09462 seconds (74.12% PHP - 25.88% MySQL) with 10 queries |
