#21 |
Were the RCA shields connected to chassis ground when you were measuring the voltage on the amp?
The Z48v will work in place of the N version. The power supply FETs will have no effect on the regulated voltage. You stated earlier that you had 12v on pin 14 of IC703. Unless I followed the wrong circuit. It appears that Q604 (8v reg) supplies voltage to pin 14 of IC703. Is this not correct (confirm with ohm meter)?
Links >> Basic Car Audio Amp Repair * Basic Car Audio Electronics * New Site * Basic Switching Power Supply Design * Basic Computer Skills << Links |
#22 |
I had them grounded when measuring the 2nd ground
indication circuit..when checking the regulated voltage i didnt had them grounded- I can confirm that IC703 pin 14 is directly connected to Q604 wich has excatly 8 volts out.... Have to measure the voltage on IC702 again...strange last time i measured i had 12volts with a small pulse. About the +-15volt reg circuit...its taking voltage directly after the rectifyer and feeding into the regulator circuit(15volts) And IC702 (the battery indicator IC) takes the supply voltage from this +-15Reg.. And its not giving me +-15Volts :S Measured it to +17,5 and -13,3 wich in my eyes isnt good. I am going to take a sleep now :P just find more and more to dig in, and its not good to fault finding several things simultanius =) |
#23 |
Measure the regulated voltage again but this time, place the black meter lead on the RCA shield of the amp.
#24 |
after replacing some pow-fets i measured the
regulated voltage with black lead on rca ground. Perfekt! ![]() takes a week for my local shop to get me another DTA144EK ![]() and if i order from digikey.com ord mouser they take 50$!!!! in shipping flat rate... no way... whatg should i dois it possible to just take a transistor from my junk boxes and bias it with two 47k resistors as the DTA144 is biased? or is it just a stupid idea :S Cant measure the voltages untill i have the componet in circuit i guess :S |
#25 |
IC702
1 -13.6 2 5.3 3 6 4 -15 5 0.28 6 14,3 7 14,3 8 14,9 SHOULD BE (15,5) (4,67) (7,1) (-15,8) (1,8) (1,5mV) (1,8) (15,9) IC703 1 0-10v pulsing 2 0.2 3 0.3 4 0-10v pulsing 5 0-10v pulsing 6 9.4p 7 0.3 8 11.5 9 0.28 10 0-10v pulsing 11 0.3 12 0.3 13 0-10v pulsing 14 0.3 SHOULD BE pin1 1 pin2 7.4 pin3 1 pin4 1.7mV pin5 1 pin6 15.5mV pin7 1.6mV pin8 11mV pin9 1.7mV pin10 1.7mV pin11 1.8mV pin12 1 pin13 1.6mV pin14 8V Very strange readings, what the hell??? have all ICs gone wacked? :S The 8 volt supply is ok ive checked it! and the +-15 volt reg is OK... what is happening here
#26 |
Now i discovered that 8volt Reg is NOT OK!!!
With RCA ground connected to chassi ground 11.66V 11.5V 12.4V Without RCA ground. 6.46V 9.4V 7.0V What is going on :S not strange that the ICs have 14,5 volts with a small pulsing on them... |
#27 |
You have to be careful of the reference you use. If you leave the RCA shield grounded, you can use either the chassis ground or the shield as the reference. I'd suggest that you connect the shield to the chassis ground for all future measurements.
What is the voltage across ZD601 (black lead on anode)? What is the voltage from the anode of ZD601 (black lead) to the emitter of Q604? Is the voltage between the anode of ZD601 and chassis ground 0v.
#28 |
---Ok then i will ! ![]() What is the voltage across ZD601 (black lead on anode)? ---Voltage across ZD601 = 8.75V What is the voltage from the anode of ZD601 (black lead) to the emitter of Q604? ---Voltage from anode ZD601 to emitter (leg 1...) of Q604 = 8.12 (someone have resolderd this before, donnow why...) Is the voltage between the anode of ZD601 and chassis ground 0v. ---Voltage from anode ZD601 ---->>> chassie with black lead on RCA ground (still with chassie ground tiead to RCA shields = 0.82 Isnt that strange ? =) |
#29 |
The regulator components appear to be OK. There may be a bad solder joint between the chassis ground and the anode of ZD601. Desolder and resolder all of the connections on Q604 and D601. If you still read nearly 0.9v, you need to determine why. There shouldn't be more than 0.1v. Ideally, there would be a 0.0v difference. The 0.82 difference probably isn't a real problem but it could indicate that there's a bad connection somewhere which could cause intermittent problems. I'm assuming that you still read 0v between the RCA and chassis grounds.
#30 |
Hello Perry!
Now i have replaced ALL caps on the power supply board! And i cleaned the "soldering" side gentle with some topz and flux off as good as i could between components and around the ICs. Did the same thing on the "component" side. Was a lot of "dust" on the board around the cooling fan and dust had stuck between components (just a layer of dust...) Not like dust balls :P whatever... Now i have a reading of 0.002V if i place a lead on the Zener and to ground (still with RCA ground connected to chassi) Strange thing is that IC701 pin4 (is connected After ic 703) here i have exactly 8Volts!!! Rock steady... On IC703 pin 14 i still got around 11 volts with a small pulsing around 10,8 and 11 volts..... the same frequensy as the LEDs flashing. A very strange thing is if i place one lead on pin 4 of IC701 and the second on IC703 i get some wierd ohm reading. Can i say from this that IC703 is leaking internally? There would be nice if i could remove it without destroying the IC. 6 legs on each side :S Any tips of how to remove it with a ordinary soldering iron? I have two of them if needed, even 3 :P But not 6 of them!! :P If i could remove it then i could measure pin 14 without the IC in place to see if i have 8Volts.... |
| Parallel LM3886, input ground, power ground, safety resistor and oscillations. | markiemrboo | Chip Amps | 5 | 9th August 2007 03:50 PM |
| DC filament ground and high voltage ground | mikeyho | Tubes / Valves | 0 | 15th September 2005 05:52 PM |
| Chassis Ground = Circuit Ground --> Problems? | rhildenbrand | Pass Labs | 5 | 23rd April 2004 01:08 AM |
| does connecting mains ground with circuit ground create a ground loop? | jarthel | Everything Else | 0 | 25th June 2003 12:55 PM |
| Should I directly connect my signal ground to chassis ground? | Bricolo | Solid State | 3 | 28th February 2003 05:31 PM |
