Alpine MRV-1507 - RCA Ground Floated - Need help
Old 5th June 2008, 06:01 PM   #41
silversweden is offline silversweden  Sweden
Pin 14 of IC703 connects to middle leg of Q801.
And yes, i am completly sure. Followed the trace with magnifyer.
Its a clear and visible trace!
But i cant see this on schematic :S
It should have E14.3 C14.1 B13.1Volts.
And it has!! Not strange that IC703 has ~13 volts on leg 14..
Is it a possebility that there are slightly different versions
of this amp? Because the schematic does not seem to match.
Or is it just me...
Maybe i should just put everything back in place and se how it works. Its frustrating when the schematic does not match the
circuit board...
Old 5th June 2008, 07:20 PM   #42
Perry Babin is offline Perry Babin  United States
It's entirely possible that the schematic and the amp you have are different. Many amplifiers have multiple versions.
Alpine MRV-1507 - RCA Ground Floated - Need helpHide this!Advertise here!
Should I directly connect my signal ground to chassis ground? Bricolo Solid State 4 18th March 2014 10:42 PM
Parallel LM3886, input ground, power ground, safety resistor and oscillations. markiemrboo Chip Amps 5 9th August 2007 04:50 PM
DC filament ground and high voltage ground mikeyho Tubes / Valves 0 15th September 2005 06:52 PM
Chassis Ground = Circuit Ground --> Problems? rhildenbrand Pass Labs 5 23rd April 2004 02:08 AM
does connecting mains ground with circuit ground create a ground loop? jarthel Everything Else 0 25th June 2003 01:55 PM
Copyright ©1999-2017 diyAudio
